Air Sealing - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2012, 08:22 PM   #1
Rewards Points: 150
air sealing
Would the PL-300 be ok to seal the seams and at the concrete floor with xps? Do I really need to get spray foam in a can for this? Tyvek tape will go over it. I just don't 100% trust the tape to last for years in all it's stickiness.
Mijotter is offline   Reply With Quote
Old 12-07-2012, 12:05 AM   #2
Rewards Points: 150
Anyone know? I don't trust that Great Stuff as I have not read that it's compatible with xps board and don't want it damaging it. The gap at the bottom and the concrete floor is very minimal. Would that PL-300 work for a proper seal?
Old 12-08-2012, 09:02 PM   #3
Registered User
Rewards Points: 526
Yes, the foamboard has been known to shrink over time, loosening tape and breaking adhesive bonds. I'd use canned foam, personally; http://www.buildingscience.com/docum...a-foam-shrinks
Gary
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing basement floor/wall gap countryboy43 Building & Construction 7 06-12-2010 10:00 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
Grout lightened after sealing SueT Tiling, ceramics, marble 6 11-23-2008 08:58 PM
