Air Sealing This ? - Insulation - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-03-2012, 10:31 AM   #31
Rewards Points: 240
ok, good. now, here is what i am thinking. 2" fb cut to nearly fit the cavity. then i spray foam all largish voids in the sheathing(there are only a few). spray foam around the parameter of the cavity where the framing meets the T&G sheathing. then press the FB into the cavity. in doing this, the sf will mush out and seal all around the fb to the studs. then i would double stud(thermal break) the framing and add insulation (after running the electrical). calk the studs/plates/electrical boxs and holes for the wires and install drywall.
good plan ? if not, please modify it.
Fix'n it is offline   Reply With Quote
Old 06-04-2012, 08:00 AM   #32
Rewards Points: 240
no comments ,
Old 06-05-2012, 06:43 AM   #33
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Nothing about that thermally uncouples the framing.
That has to be done from the outside surface.
That framing is still going to be cold but if you seal up all the interior drywall, you should be fine.
Bulk air movement is the killer when it comes to condensation. Almost none comes via diffusion.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (06-05-2012)
Old 06-05-2012, 08:51 AM   #34
Rewards Points: 240
really ? i thought that if the outside framing is separated (at least in the middle) from the inside framing. cold would not transfer nearly as easy as just regular framing. as said here, pg27
http://www.buildingscience.com/docum...ermal-analysis
so the end R-value would be higher, i am thinking.
Old 06-05-2012, 08:58 AM   #35
Rewards Points: 240
let me put that a different way :
the sheathing is separated from the drywall.
there would be a lot less thermal bridging.
but, in the end = would it be worth the effort ?
Old 06-05-2012, 10:05 AM   #36
That will help with the thermal transfer to the interior side of the home but not with any of the potential condensation issues inside the wall.
That is what I was referring to. By thermally uncoupling the interior side, you are potentially making the issue more severe because the framing will stay that much colder.
Old 06-05-2012, 09:21 PM   #37
Rewards Points: 240
ok. well. i am going to install that one window. while doing so, i will be able to see just what is on the outside. then i will report back.
Old 06-13-2012, 03:31 PM   #38
A quick and easy way to seal might be Owens Corning. It's a two step air insulation system at a fraction of the cost of some of the others. It looks like something that could definitely help remedy the situation, but ----------- and see what you think.
Last edited by Gary in WA; 06-14-2012 at 10:50 PM. Reason: Removed web ad link that belongs under your signature line.
jaspertommy is offline   Reply With Quote
Old 06-14-2012, 06:31 AM   #39
Originally Posted by jaspertommy View Post
A quick and easy way to seal might be Owens Corning Energy Complete. It's a two step air insulation system at a fraction of the cost of some of the others. It looks like something that could definitely help remedy the situation, but check it out and see what you think.
There is a bunch of suspicious OC postings lately under different names.
Part of OC market capture strategy?
Old 06-14-2012, 08:16 PM   #40
Rewards Points: 240
3 minutes googling. i found that that stuff is not DIY.
Old 08-05-2012, 02:52 PM   #41
Rewards Points: 240
ok, fella's. i have 1 window mostly/kinda in.
my T&G sheathing. there is no house wrap over it. it has a mortar looking stuff to fill the slots. the slots, they were cut into the T&G. idk why.
and then the asphalt siding.
so, how does this effect my air sealing ? right now the plan is 1" foam board,
and 3 1/2" roxul. with 1" wood added to the studs. and, hopefully kinda soon, but idk when really. i am going with xpf under the new siding.
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 08:05 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
