Air Sealing This ? - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 10:50 PM   #16
Rewards Points: 626
Originally Posted by Fix'n it View Post
my exterior walls use T&G boards. are these basicly(good enough ?) air sealed ? if not, what is an economical way of sealing it ?
Do the KISS system from Knauff Eco seal it then insulation. Works very well zero VOC.
Nailbags is offline   Reply With Quote
Old 05-29-2012, 06:28 PM   #17
Tom Struble's Avatar
Rewards Points: 2,002
i understand but you can understand it's tough to make a recommendation when the variables are not really known
as far as the air sealing,i would follow windows on washingtons suggestion
good luck with your project
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Fix'n it (06-10-2012)
Old 05-29-2012, 08:29 PM   #18
Rewards Points: 236
fair enough. i am not going to be insulating for a while anyway. so i will get the windows and install that one. at that time i will know what is there, and report back.
WoW and joe have the ideas that fit my budget the best (afaikn).
thanx you. right now, i need all the blessings i can get
Fix'n it is offline   Reply With Quote
Old 05-30-2012, 11:57 PM   #19
Registered User
Rewards Points: 526
Installing a housewrap outboard of the cavity insulation for an air barrier would do little to stop airflow from the interior through holes in the drywall. Just side stapling H.W. would be useless as an air-barrier which requires continuous coverage.
In your cold climate, the heated air is ex-filtrating out most of the year, not coming in (infiltrating). Diffusion would be small scale compared to air leaks under drywall or around electrical boxes. Pages 3-8; http://www.buildingscience.com/docum...researchreport
You need an interior vapor retarder if no f.b. on exterior, bottom of page 7. Control you indoor RH as in fig. 9.
If unable to use exterior foam board, ADA the drywall after using a paper-faced insulation batt- fig. 5, keep the air from going out through drywall leaks. http://www.buildingscience.com/docum...wall-approach/
The importance of exterior f.b. and added cavity insulation, notice the dew-point differences; http://www.buildingscience.com/documents/digests/bsd-controlling-cold-weather-condensation-using-insulation/view
Relate the steel studs with dew points to cavity f.b. rather than on exterior.
You have to air-seal the drywall, no inset stud stapling of faced batts, full-contact of insulation with drywall- even 1/32” will damage you, and use a “smart vapor retarder” like asphalt faced batt or “MemBrain”; https://docs.google.com/viewer?a=v&q...sNmmYf-psHZnLA
Ginger vs. MaryAnn; http://www.buildingscience.com/docum...024-vocabulary
http://www.bestofbuildingscience.com...3-4_p37-40.pdf
Gary
Old 05-31-2012, 01:41 AM   #20
Rewards Points: 626
Gary
Well you can use non faced batts and use a 4 mil plastic vapor retarder from top plate to bottom plate and seal it up good to right?
Old 05-31-2012, 01:21 PM   #21
Registered User
Rewards Points: 526
Is this for our climate in the Pacific Northwest? If so, poly v.b. are dangerous with engineered wood materials, OSB, etc., pp. 46-50: http://apps1.eere.energy.gov/buildin...rica/38449.pdf
Notice they site the test by BSC I already used, here it is again- in easier to understand form; http://www.buildingscienceconsulting...Strategies.pdf
BSC recommends using more permeable materials- in general- (when it will work) than poly in all cases: http://www.buildingscience.com/docum...commendations/
Around Seattle local climate, poly is suggested only when indoor RH is above 60%, pp. 50, 51 and 57; http://www.ornl.gov/~webworks/cppr/y2001/rpt/113799.pdf If you couple that fact with the low drying ability of OSB, better to use a variable vapor retarder as I mentioned already. Poly is for much colder climates.
Fig. 2a, 2b show our walls, read page #7 especially; http://www.buildingscience.com/docum...nd-wall-design
Gary
Old 06-01-2012, 12:23 PM   #22
Registered User
Rewards Points: 526
Found the one I was thinking of- poly in Zone 6 or higher, fig. 10: http://www.buildingscience.com/docum...control_ed.pdf
Gary
Old 06-01-2012, 09:15 PM   #23
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
As always, good information in GBR's links.
Old 06-01-2012, 11:12 PM   #24
Rewards Points: 626
Now my real question talking to some real old timers who built more homes then I ever would or will say that homes to day are to air tight and need to leak air like the old days. so that if moisture does get in to the wall it can go some were and not rot out the sheathing or build mold galore. So maybe just good old fashon fiberglass and face nailing is the way to go? Who knows?
Old 06-02-2012, 12:14 AM   #25
Registered User
Rewards Points: 526
It has been studied a lot..... Impact of cavity air-tightness- eg. 35% R-value reduction, wind-tightness- 10-40%, air gap on the warm side of f.g. = 300% heat loss in examples; 2a, 2b: http://www.aecb.net/PDFs/Impact_of_thermal_bypass.pdf
There are quite a few air/moisture leakage pathways for infiltration/exfiltration on all houses: http://www.conservationtechnology.co...eakagePathways
Of course now we use OSB (engineered wood) and it has it's own bucket o' problems. Why not drill some holes in it to speed-up drying of the cavity.....pp.22, 23: http://www.nrc-cnrc.gc.ca/obj/irc/do....2/b1239.2.pdf
Holes under window for ventilation---- I do like the rest, though, especially the end dams on head flashing, pp8: http://www.mtcc1170.com/images/BCRainScreen.pdf
Thanks, WoW, they are worth researching for.
Gary
Old 06-02-2012, 12:59 AM   #26
The Best and only way to cover all your needs here is have all the wall cavities professionally sprayed foamed.
I'm a bit of an insulation expert on another site and the bottom line here is the extra cost of spray foam will easily pay in savings of heating that space in short years .
The R values in foam are tremendous for density. We spray foam Cathedral ceilings and that solves ALL the problems of vapor barrier and R values that needs to be obtained.
http://www.energystar.gov/index.cfm?...sulation_table
http://www.xpsa.com/tech/Tech%20Talk...lue%20Roof.pdf
http://www.spray-foam.com/compare.html
http://www.tigerfoam.com/
21boat is offline   Reply With Quote
Old 06-02-2012, 10:29 PM   #27
Registered User
Rewards Points: 526
SPF is certainly the best but certainly not the most economical way to seal it. As it is T&G, there would be very little air/moisture coming in due to a heating climate. Outgoing air, possibly, though T&G still covers an open air gap when the boards expand and contract with the seasons due to the locking effect. I agree with air sealing the cavity, even the small cracks if absolutely necessary in the OP's mind. Use some canned foam, caulking or tape, in addition to f.g., rock wool or better still- cellulose totaling 1/3 or 1/4 the cost of full cavity SPF: http://www.ornl.gov/sci/buildings/20...s/80_Bibee.pdf
Remember too, we are a DIY site, not "hire a pro".
Gary
Old 06-02-2012, 11:29 PM   #28
Rewards Points: 626
So my question now is this. We build homes so air tight and have to seal them up it makes Tupperware look like a sieve. Then they have you put windows in with open vents and install a whole house fan that moves 100 cmf twice a day for eight hours each time. Sucking out all the warm or cold air in your home when if you left well enough a lone and not seal you your home it would do the same thing as having open vents on your windows and a whole house fan keeping a constant draft in your home. Sheeah! why even do it?
Old 06-03-2012, 08:42 AM   #29
Rewards Points: 236
ok. lets assume that in the future, year or 2, i can reside the house. and i decide to use foam board on the outside, over my existing asphalt siding.
and lets say i currently decide to use foam board on the inside of the sheathing sealed with spray foam.
how will this effect the T&G sheathing ?
Old 06-03-2012, 10:01 AM   #30
If you air barrier details are not spot on from the interior foam side, the T&G could rot.
It will be more likely to sweat with any bulk movement of relative humidity because it will be much colder as a result of the thermal uncoupling of the rigid foam board.
Foam to the outside will keep the T&G warmer and in doing so, ward off condensation.
You can use rigid foam to the interior but you have to be extra careful with your sealing.
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 08:05 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
