Air Sealing This ? - Insulation - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 08:03 AM   #1
Rewards Points: 236
air sealing this ?
my exterior walls use T&G boards. are these basicly(good enough ?) air sealed ? if not, what is an economical way of sealing it ?
Fix'n it is offline   Reply With Quote
Old 05-27-2012, 08:04 AM   #2
Rewards Points: 236
oh. i, as of yet, know what is on the other side of this. between the T&G and the siding.
Old 05-27-2012, 08:20 AM   #3
the Musigician
DangerMouse's Avatar
Spray foam it?
DM
Old 05-27-2012, 08:43 AM   #4
Rewards Points: 236
Originally Posted by dangermouse View Post
spray foam it?
Dm
Old 05-27-2012, 09:18 AM   #5
Rewards Points: 13,458
May not be the best way but in the past we have cut stips of Tyvek and stapled them up then insulated.
It still allow the wall to breath and cut down the air flow a great deal from the outside.
Make sure you add fire blocking at the top and bottom of these walls, and in the middle if the ceilings are over 8' tall.
Old 05-27-2012, 09:21 AM   #6
Rewards Points: 528
Joe, the actual code on fire blocking is anything over 10' tall.
Around here on exterior wall we get around fire blocking as most homes are insulated with fiberglass.
framer52 is offline   Reply With Quote
Old 05-27-2012, 12:02 PM   #7
the Musigician
Originally Posted by Fix'n it View Post
Are you near/in Wa.? Maybe you and MzMolly65 can share the cost of getting the DIY spray foam kit and save tons of $$$.
Barb (gma2rjc) can tell you approximate costs and any other helpful hints if she sees this or we all yell her name loud enough. She did the DIY spray foam thing and was happy with the cost and results, and this IS a DIY website!
You may be surprised how affordable it is!
DM
Old 05-27-2012, 10:55 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,150
Spray foam or rigid foam cut to fit in the stud bays that is then sealed to the studs and sealed up tight.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (05-28-2012)
Old 05-28-2012, 08:34 AM   #9
Rewards Points: 236
joe. i was thinking just that.
Old 05-28-2012, 08:45 AM   #10
Rewards Points: 236
i was also thinking this. how thick would you recommend ? = for 4" or 6" wall depth.
Old 05-28-2012, 08:48 AM   #11
Rewards Points: 236
that spray foam. can a guy spray 1/2 the tank. then use the other half weeks later ?
Old 05-28-2012, 08:53 AM   #12
Tom Struble's Avatar
Rewards Points: 2,002
can you see any paper or felt thru the cracks?
Tom Struble is offline   Reply With Quote
Old 05-28-2012, 09:08 AM   #13
Rewards Points: 236
there are no cracks. its T&G wood.
ok, i just looked again. i found a bad spot. it looks like there is the back side of the asphalt siding. but it could be that the paper, if it was installed, has been damaged = gone, in that spot.
i will not "know" until i go to put the new window in. and that is probably(if i go with the okna windows) a month off.
Old 05-28-2012, 10:21 AM   #14
so you want to do something your really not sure your need to do and your not really sure what you have,but may find out sometime in the future
i guess you can just follow any recommendation then
Old 05-28-2012, 07:17 PM   #15
Rewards Points: 236
Tom. i want to do the right things, as best i can, with what i have to work with. while i am not made of money, i do have some, and i need to be wise with it. the one thing i am short on, is knowledge. that is why i am here trying to learn from you guys.
The Following User Says Thank You to Fix'n it For This Useful Post:
Tom Struble (05-29-2012)
Air sealing attic mmastran Insulation 11 05-25-2011 07:31 AM
sealing compound?! mmhendrie Electrical 1 07-18-2010 06:51 PM
Sealing new boxes on an exterior wall Mthrboard Electrical 1 08-16-2009 08:05 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 06:36 PM
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
