-   Insulation (http://www.diychatroom.com/f103/)
-   -   air sealing this ? (http://www.diychatroom.com/f103/air-sealing-145001/)
Fix'n it 05-27-2012 08:03 AM
air sealing this ?
1 Attachment(s)
my exterior walls use T&G boards. are these basicly(good enough ?) air sealed ? if not, what is an economical way of sealing it ?
Fix'n it 05-27-2012 08:04 AM
oh. i, as of yet, know what is on the other side of this. between the T&G and the siding.
DangerMouse 05-27-2012 08:20 AM
Spray foam it?
DM
Fix'n it 05-27-2012 08:43 AM
Originally Posted by dangermouse (Post 929661)
spray foam it?
Dm
joecaption 05-27-2012 09:18 AM
May not be the best way but in the past we have cut stips of Tyvek and stapled them up then insulated.
It still allow the wall to breath and cut down the air flow a great deal from the outside.
Make sure you add fire blocking at the top and bottom of these walls, and in the middle if the ceilings are over 8' tall.
framer52 05-27-2012 09:21 AM
Joe, the actual code on fire blocking is anything over 10' tall.
Around here on exterior wall we get around fire blocking as most homes are insulated with fiberglass.
DangerMouse 05-27-2012 12:02 PM
Originally Posted by Fix'n it (Post 929669)
Are you near/in Wa.? Maybe you and MzMolly65 can share the cost of getting the DIY spray foam kit and save tons of $$$. :laughing:
Barb (gma2rjc) can tell you approximate costs and any other helpful hints if she sees this or we all yell her name loud enough. She did the DIY spray foam thing and was happy with the cost and results, and this IS a DIY website! :)
You may be surprised how affordable it is!
DM
Windows on Wash 05-27-2012 10:55 PM
Spray foam or rigid foam cut to fit in the stud bays that is then sealed to the studs and sealed up tight.
Fix'n it 05-28-2012 08:34 AM
joe. i was thinking just that.
Fix'n it 05-28-2012 08:45 AM
i was also thinking this. how thick would you recommend ? = for 4" or 6" wall depth.
Fix'n it 05-28-2012 08:48 AM
that spray foam. can a guy spray 1/2 the tank. then use the other half weeks later ?
Tom Struble 05-28-2012 08:53 AM
can you see any paper or felt thru the cracks?
Fix'n it 05-28-2012 09:08 AM
there are no cracks. its T&G wood.
ok, i just looked again. i found a bad spot. it looks like there is the back side of the asphalt siding. but it could be that the paper, if it was installed, has been damaged = gone, in that spot.
i will not "know" until i go to put the new window in. and that is probably(if i go with the okna windows) a month off.
Tom Struble 05-28-2012 10:21 AM
so you want to do something your really not sure your need to do and your not really sure what you have,but may find out sometime in the future
i guess you can just follow any recommendation then:thumbsup:
Fix'n it 05-28-2012 07:17 PM
Tom. i want to do the right things, as best i can, with what i have to work with. while i am not made of money, i do have some, and i need to be wise with it. the one thing i am short on, is knowledge. that is why i am here trying to learn from you guys.
