Air Seal Rim Joist Cavity Thats Only 3" Deep?? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-25-2015, 05:11 PM   #1
Rewards Points: 145
air seal rim joist cavity thats only 3" deep??
I was gonna seal with 2" rigid foam but that only leaves me with 1" for roxul r14?
Or should I do 1.5" xps and then the batting will sort of sit on top of the wall frame/ wall xps??
Also should I seal rim joist cavity with canned spray foam or is caulk ok? If caulk what type?
wantboost is offline   Reply With Quote
Old 03-26-2015, 11:26 AM   #2
Rewards Points: 54
is the roxul for fireproofing? if so, you can use drywall, cut to fit and keep the 2" of foam. foam or caulk are both fine, depending on the size of the gap. Any good quality latex would work.
wetech is offline   Reply With Quote
Old 03-26-2015, 02:29 PM   #3
Rewards Points: 145
Roxul is to insulate as well as fireproof. What type of caulk fireproof? Or will spray foam seal better
Old 03-27-2015, 09:11 AM   #4
Rewards Points: 1,480
Could you add an inch of xps on top of the two inch? XPS is r5 per inch. An inch of Roxul is only between r3-r4 I think. You'll be drywalling over everything anyway or no?
mikegp is offline   Reply With Quote
Old 03-27-2015, 09:24 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
Just use the foam and cover with Drywall for your fireproofing.
Are you finishing the basement? Is the fireblocking done?
Old 03-27-2015, 04:50 PM   #6
Rewards Points: 145
It's a shallow basement ( 58")
Only. Used for storage.
I was gonna seal rim joist cavity with 2" rigid foam but that only leaves me with 1" for roxul r14?
Old 03-27-2015, 11:28 PM   #7
Rewards Points: 145
Also should I seal rim joist cavity with canned spray foam pro foam or just reg foam and or fireproof foam?
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Cracks in joist clydesdale Building & Construction 4 01-04-2011 08:08 AM
rim joist insulation nightmares.. BlueBSH Building & Construction 0 06-01-2010 09:11 AM
Floor Joist damage - bathing my way to disaster? Leah Frances Building & Construction 3 01-27-2008 10:33 PM
Insulating 3" Wall Cavity Riddler Building & Construction 5 07-01-2006 07:13 AM
