Air Handler - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 01:13 PM   #1
air handler
We have an air handler in our attic and although the attic is well insulated, it is still quite cold up there in the winter. In an attempt to control heating costs, would it make sense to wrap the air handler with insulation or maybe some type of product out there specific for air handlers? Maybe you should never cover an air handler, I don't know. Our attic space is totally dry, never any condensation on the air handler, etc.
Thanks,
Janice D.
jdecker22 is offline   Reply With Quote
Old 01-08-2012, 01:35 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by jdecker22 View Post
...although the attic is well insulated, it is still quite cold up there in the winter.
"They all do that, Ma'am" In fact, they're supposed to.
We have an air handler in our attic...
The duct should certainly be insulated...
but not the equipment itself.
hth
The Following User Says Thank You to TarheelTerp For This Useful Post:
Windows on Wash (01-09-2012)
Old 01-09-2012, 07:44 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
hth
+1
Are the duct lines rigid or flex? More of the inefficiency losses are are via forced air losses through the duct connection to the attic.
If they are flex lines, cut the straps down that support the lines up and put them in the insulation along the floor.
Air handler leaking kcamnairb HVAC 4 08-17-2011 04:32 PM
SPace Pak Air Handler Wiring Question--208-230/60/1 metal121 HVAC 5 05-07-2009 05:52 AM
Space Pac Air Handler Wiring--208-230/60/1 Volts metal121 Electrical 4 05-05-2009 10:20 AM
Proper way to clean the air handler drain lines lithium1330 HVAC 2 11-25-2008 09:48 AM
Replacing air handler - How to fit when form factors are slightly different?? hennyh HVAC 2 11-16-2006 08:23 AM
