Air Gap Between Brick And Plaster In The Attic - Insulation - DIY Chatroom Home Improvement Forum
Old 12-28-2016, 08:09 PM   #1
Air gap between brick and plaster in the attic
I live in a 1950's end unit townhouse and am working on bumping up the attic insulation. I've been reading and learned about the reason for the air space/air gap between the exterior brick and the plaster wall. What's the correct way to deal with this gap in the attic? Do I leave the blown in insulation covering it in place, remove the insulation, or something else?
jrml is offline   Reply With Quote
Old 12-29-2016, 09:37 PM   #2
Registered User
Rewards Points: 5,514
Re: Air gap between brick and plaster in the attic
--------------Welcome to the forums!-----------------------
Pics would sure help...
Usually the wall space is blocked off from the attic or else the wet air (moisture on the back of brick/WRB) communicates to the attic. FG won't stop it. Need to make sure the top space has openings to front of bricks first- by way of fascia/freeze board- or out past brick by soffit area in front; https://buildingscience.com/document...voir-claddings
Gary
Old 12-30-2016, 05:31 AM   #3
Gary - thanks for the link, that explains a lot!
In my case, the space is not open to the outside, which leads me to believe that I should leave the air gap uncovered. I've attached a picture (if it works) that shows how it looks from the attic.
Old 01-01-2017, 06:55 PM   #4
Registered User
Yes, if that is the only outlet, leave it be (and clean it out). Add some baffles (for clear air channel) in front of your blown-in so it doesn't get wind-washed and protect it from air movement which degrades the R-value. IF FG- as in pic.-, think about adding a few inches of cellulose over the top to stop convective loops and muting the R-value of the top few inches of blown-in FG from cold air flowing in the intakes or from behind brick. Or if you have or are able to build a cat-walk, you can install housewrap from there -- over the top to handle same. Links if needed.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
jrml (01-07-2017)
Old 01-07-2017, 09:22 AM   #5
Gary
I installed baffles, will clean up the insulation on top of the gap/outlet and go from there.
Thanks again for the recommendations!
The Following User Says Thank You to jrml For This Useful Post:
Gary in WA (01-07-2017)
Brick Veneer to plaster walls salves77 Concrete, Stone & Masonry 3 04-07-2015 01:35 PM
Fixing a gap between plaster wall and brick wall eholmes77 Drywall & Plaster 3 05-20-2014 10:31 PM
outside corner -- plaster meeting exposed brick amakarevic Drywall & Plaster 0 12-29-2012 03:03 PM
trying to match interior plaster over brick ironnickwhite Drywall & Plaster 2 11-14-2012 07:38 PM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 01:55 PM
