Advice Please - Insulation - DIY Chatroom Home Improvement Forum
Old 03-11-2014, 10:29 AM   #1
advice please
PLEASE HELP! I live in a ranch house built in the late 40's. Two of the bedrooms are above the garage. I'm from Pa. & we've had a horrible winter this year. as a result, the BRs have been colder than usual. I want to insulate the garage. Here's the rub. The previous owner has insulated the joists with what I think is asbestos based insulation and finished the ceiling with 10 x 10 squares. A peek at the insulation tells me it has flattened & broken down over the years. I'm looking for the easiest fix. Can I put foam based sheeting over the entire mess and then drywall or will I ahve to remove everything & start from scratch? I don't wnat a super hor BR, just an undrafty one. Advice please..
Joe Goots is offline   Reply With Quote
Old 03-13-2014, 05:22 AM   #2
DIY staff
Rewards Points: 7,174
Have a sample of the insulation checked for asbestos----if it is positive---then we'll talk---
Windows on Wash (03-13-2014)
Old 03-13-2014, 07:13 AM   #3
As oh,mike says, or get someone (a professional) out there to check it out ASAP. Fingers crossed.
DIYRemodeler is offline   Reply With Quote
Old 03-13-2014, 10:07 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Figure out what type of asbestos it is. Even minimally disturbance of it (i.e. putting up foam over top) can make it friable, depending on the type.
Don't mess with this stuff unless you know what you are dealing with in terms of type and exposure risks.
Old 03-13-2014, 01:01 PM   #5
Rewards Points: 808
I'm having trouble figuring out what type of asbestos-based insulation could ever be used to insulate ceiling joists from below?
IslandGuy is offline   Reply With Quote
The Following 2 Users Say Thank You to IslandGuy For This Useful Post:
Fix'n it (03-17-2014), oh'mike (03-14-2014)
Old 03-17-2014, 12:58 PM   #6
All clear. The "asbestos" were nothing more than crumpled pieces of very old fiberglass product.
Advice is not always correct! Docwhitley Plumbing 9 02-14-2011 09:12 PM
Chain link fence install advice ponch37300 Landscaping & Lawn Care 1 11-10-2010 06:08 PM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
looking for Serious advice and Help on Insulation bfan781 Building & Construction 6 05-19-2010 11:02 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
