Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-24-2011, 06:59 PM   #1
Question
adding xps insulation to the out side of a mobile home
Hello all I'm new to the forum and I have a couple of Questions we have a mobile home which we use as our cottage this summer we want to put on new Vinyle siding and put in new windows and we also want to beef up the insulation on the trailer and were going to add 1.5 inch xps insulation foam board on the outside of the trailer the problem I'm having are
1. should we use house wrap before the insulation if we use house wrap at all.
2. how to we instlal the windows with the foam insualtion
My orginal thought was to put on the insulation then the house wrap and then install the windows
I should also mention the mobile home only has 2x3 walls and the cabin is located in canada were the winters are very cold.
any help you guys could provide me or point me in the right direction would be much appreciated
Fred84 is offline   Reply With Quote
Old 04-25-2011, 08:06 PM   #2
Moderator
Welcome to the forum!
Some reading for you, find Waldo.... http://www.greenbuildingadvisor.com/...s-housewrap-go
http://www.greenbuildingadvisor.com/...istive-barrier
http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
And finally; http://www.mtcc1170.com/images/BCRainScreen.pdf
"or point me in the right direction"--- you asked for it! lol
Gary
Clothes taking longer to dry?
Old 05-08-2011, 12:10 AM   #3
Thanks Gary much appreciated
Gutting a Mobile Home thebeckscr Building & Construction 11 01-17-2011 01:48 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General Discussion 5 11-08-2010 11:50 AM
Rafter Vents and Insulation nofx1981 Roofing 15 03-10-2010 09:14 PM
adding attic insulation to existing insulation strouddljs General Discussion 4 11-09-2009 06:06 PM
