Adding Polyiso To Knee Wall - Insulation - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bud9051
Old 01-01-2017, 08:07 AM   #1
Adding polyiso to knee wall
I am getting ready to finish out a bonus room above my garage. Once the rough electrical has been inspected i will start the insulation process. I live in zone 3. when insulating the knee walls, i want to use foil face polyiso (1" thermax) on the back of the knee wall. Does the foil face toward the attic or toward the conditioned space? I will be using kraft faced fiberglass batts. Didnt know if i would be putting the fiberglass between 2 vapor barriers or not. I fully intent to reaaly seal it up as well to prevent air leakage.
Sports75 is offline   Reply With Quote
Old 01-01-2017, 08:51 PM   #2
Re: Adding polyiso to knee wall
Never mind....bought some 1" polyiso today and didnt realize it was foil face on both sides!
Old 01-02-2017, 05:46 AM   #3
Rewards Points: 3,946
Just a note, but it is possible the foil on the two sides are not equal. Thermax has been tested to be left exposed with no additional thermal barrier but most likely only one side achieves that rating. Dow's web site or the label on the insulation should tell you which side to leave exposed. It isn't easy to find near me so I haven't personally used it.
Bud
Windows on Wash likes this.
Bud9051 is offline   Reply With Quote
Old 01-02-2017, 10:26 PM   #4
Registered User
Rewards Points: 5,524
----------------------Welcome to the forums!-----------------------
Are you in a mixed-humid climate of Zone 3?; https://basc.pnnl.gov/sites/default/...mid_121914.pdf Regardless, tape all foam board seams, after installing it on caulking beads, caulk the drywall to studs/plates joints, and canned foam any wiring/plumbing holes. Where is the house? State...
Gary
Adding a two row curved CMU wall to pool... Chris fox Concrete, Stone & Masonry 7 01-29-2014 08:48 AM
Insulate Basement Knee Wall RachWashState Concrete, Stone & Masonry 6 09-24-2013 02:48 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Framing stair knee wall... bparise Carpentry 6 11-14-2009 12:03 AM
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 09:14 AM
