Adding More Fiberglass Insulation On Top Of R19 In Attic - Insulation - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 06:52 AM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Originally Posted by aminus21 View Post
Wonderful, thanks for the advice everyone.
I don't want to go with cellulose or blown in fiberglass in the attic because it gets too messy.
Currently, the R19 that is up there between the joists is unfaced, but the "comfort touch" (plastic wrapped) insulation. I'd like to add another layer of the same stuff (R19 comfort touch), because I don't like to get itchy when I go in the attic for plumbing or storage. Is it okay to have two layers of unfaced comfort touch? Would it trap in moisture?
Messy?
Cellulose will not damage your lung tissue or create the irritation in your skin. That is reason enough to use it.
As AG said, the plastic insulation you have up there is all wrong. You need to pull that plastic layer ASAP.
Blown in insulation for un-insulated attic Cubey Insulation 10 10-19-2011 07:08 PM
Damp Insulation in Attic wiz561 Building & Construction 6 12-23-2010 11:16 PM
Attic insulation problem Dan77 Building & Construction 7 12-22-2010 02:10 PM
adding attic insulation to an old house blair1120 Building & Construction 7 02-15-2010 07:48 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
