Adding Insulation On Top Of Drywall - Insulation - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 06:47 PM   #1
adding insulation on top of drywall
We have a 2 X 4 stick built home. I am thinking of adding the thinnist highest r-value material on top of the drywall and then cover with T & G pine or other wall covering on the inside of all exterior walls. Is this possible or is their a problem with vapor barrier? or other ideas? I do not want to pull off my cedar siding and do added insulation on the outside and not sure if there is any way to blow in material since there is alread fiberglass insulation in the walls.
Thank you
terry hinkley is offline   Reply With Quote
Old 06-13-2011, 02:45 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Generally, you don't want to add insulation to the warm side of a vapor barrier. That has the potential to change your vapor barrier temperature, perhaps lowering it to or below dew point. That could cause you big problems with condensation somewhere within the wall system. When people pose insulation questions, they really need to put their location in their profile. There are huge differences in insulation practices between Florida and Canada.
Old 06-14-2011, 04:55 PM   #3
Energy Saver
HomeInsulation's Avatar
Hi Terry,
There's another reason you probably don't want to add foam board insulation over drywall and cover it with pine... It would be a fire hazard.
Foam board insulation needs to be covered with at least 1/2in of gypsum in most building codes.
I'd call a cellulose insulation contractor and ask them about dense packing cellulose from the outside. Fiberglass insulation is not very dense and their hoses can move right through it.
It's probably your least expensive option. But poured in place expanding foam can also be used in exterior walls with fiberglass insulation. It's usually 3 times the price per sq. ft.
If your home is uncomfortable or expensive to heat and cool, there's other options besides your walls that will make a huge difference at a lower cost.
Free How To Insulation Videos @
HomeInsulation is offline   Reply With Quote
Drywall over foamboard rim joist insulation Atskodinski Building & Construction 0 01-19-2011 10:03 PM
Adding Insulation to Kneewall shorteared General DIY Discussions 3 10-04-2010 06:41 PM
Adding Attic Insulation barneyrubble Building & Construction 2 08-23-2010 01:50 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Adding insulation to the underside of a high ceiling churchlady Building & Construction 6 11-17-2009 07:02 PM
