Adding Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 02:03 PM   #1
Adding insulation
I have a panelled basement, I want to add some more insulation to the walls without going as far as re studding and drywalling yet. I pulled the panelling off to find 3/4" white foam stuck to the block foundation and then a 2"x2" frame on top of the foam then panelling. I can fit 1 1/2" of rigid foam inbetween the studs. If i did all my outer walls in this way will I see much of a benefit?
tech14 is offline   Reply With Quote
Adding attic insulation rakuz66 Insulation 4 07-22-2011 06:02 PM
adding foam bd insulation to attic wall (fire code) park9472 Building & Construction 0 04-14-2010 03:17 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Adding Insulation - getting around in attic VelvetFoot Building & Construction 2 11-13-2009 02:49 PM
Adding Insulation jamiedolan General DIY Discussions 1 09-08-2008 02:43 PM
