Adding Four Inches Of Foam Board . - Insulation - DIY Chatroom Home Improvement Forum
Old 03-16-2014, 06:16 PM   #1
Adding four inches of foam board .
Ow do I attach 4 inches of foam board insulation to the inside of a cathedral ceiling?
Gerry Hendry is offline   Reply With Quote
Old 03-16-2014, 06:56 PM   #2
Framing Contractor
Rewards Points: 112
long screws with a fender washer
sixeightten is offline   Reply With Quote
Old 03-17-2014, 12:08 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Foam washers work well too.
https://www.warehousebay.com/catalog...f3f647ed90cfce
Old 03-18-2014, 02:40 PM   #4
Thanks.Would Roxall at 2ft centres and 2xframing be cheaper and more fire resistent?
Old 03-18-2014, 03:25 PM   #5
iminaquagmire's Avatar
Rewards Points: 338
What exactly are you trying to do? Fill in rafter bays with insulation? Assuming the venting is ok in the cathedral roof section and the you're ready to insulate, yes Roxul would certainly be more fire resistant, but depending on code where you are, would be harder to get to the proper R value.
iminaquagmire is offline   Reply With Quote
Old 03-18-2014, 03:53 PM   #6
I'madding insulation to an existing cathedral ceiling leaving the drywall intact.
Foam Board Insulation issues zpotas Insulation 4 04-21-2012 12:34 AM
rigid foam board on basement floor is it good or bad cutnail Insulation 6 08-29-2011 08:48 AM
Question regarding Housewrap and Foam board insulation psychomti Building & Construction 16 10-27-2010 09:50 PM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 09:17 PM
