-   Insulation (http://www.diychatroom.com/f103/)
-   -   Added R30 fiberglass rolls in my upper attic (http://www.diychatroom.com/f103/added-r30-fiberglass-rolls-my-upper-attic-189290/)
Dave Sal 10-26-2013 09:21 PM
Originally had about R30 but wanted to double up to bring it up to around R60 as is recommended for Zone 5. I have a remote thermometer probe up in the attic with the display mounted in the closet below the attic access hatch. Before the new insulation was added, the temps in the attic would be close to the outside air temps, usually within ten degrees. Now, after rolling out nine rolls of R30 on top of the old fiberglass rolls, perpendicular, and adding a new R40 weather stripped attic hatch, the temperatures up there have been close to twenty five degrees warmer than the outside air. For example, two days ago the outside air temp was about 37 degrees, yet the attic temp showed about 67 degrees. Before the addition of the new R30 rolls the temps would have been in the mid 40's. This makes no sense, and I'm starting to wonder if my remote temperature probe is now defective. Thoughts?
joecaption 10-27-2013 12:19 AM
Did you add baffles so the soffits could still vent?
What type of roof venting do you have?
If you covered up the soffits with insulation the roof vents will no longer work.
Dave Sal 10-27-2013 12:32 AM
You know, now that you mention it, I'm starting to wonder if that isn't the case. Guess the only way to check is to empty the closet and climb back up there. I wasn't able to get very close to the perimeter of the attic near the soffit vents so I don't think I covered the vents up but that's something that needs to be checked. Thanks
Windows on Wash 10-27-2013 07:56 AM
+1
Good catch Joe. I would be willing to bet you unintentionally blocked the soffits.
Get up there and get those areas clear ASAP.
Fix'n it 10-27-2013 09:37 AM
Originally Posted by Windows on Wash (Post 1258606)
+1
Good catch Joe.
+ another 1
ddawg16 10-27-2013 11:57 AM
And another one.....
Putting a thermometer up there is not a good way to measure heat loss....with proper ventilation, the attic should be the same temp as the outside air....
About the only way to get an idea is to use an infrared camera....but to have any meaningful data, you need before and after pics.
Now your just going to have to compare your energy bills and adjust for seasonal temps.
On a bright note.....you certainly did not do anything that would hurt the situation....other than block the soffetts....
Dave Sal 10-27-2013 04:20 PM
Actually, I put the temperature probe up there to check the summertime attic temps after I installed a power attic fan. It used to get up to 120 degrees in the upper attic (tri-level home) on really hot days. After the power attic vent was installed it stays below 110 even on the hottest days.
I'm going to pick up soffit baffles and go back up there (ugh!) again and get the attic breathing.
Thanks for the replies guys.
Dave Sal 11-04-2013 06:13 PM
Just a quick update....
Went back up in the attic today and crawled around in there for an hour, installing ten soffit baffles. You guys were correct. I had inadvertently stuffed the ends of the new rolls of R30 insulation between the roof rafters, close enough to the ends where it blocked the soffit vents. Now that they have been unblocked, I'm checking attic temps and found that the latest reading was 58 degrees in the attic, with the outside air temps at 53 degrees. That's similar to what it was before so I am glad I took care of it. Thanks again for the comments. :thumbsup:
Gary in WA 11-05-2013 12:04 PM
Good job, guys!
If you wanted to get more from your insulation R-value, add some house wrap over the top. R-30 is a low density batt insulation (bottom of the pile), susceptible to air movement on the top side facing attic; http://www.diychatroom.com/f98/bigge...ulation-90438/
Ventilated roofs on right-hand side; http://digitalcommons.unl.edu/cgi/vi...ventilation%22
Fiberglass is rated when in a six-sided enclosure, attic and crawlspace insulation are never covered- why?; page 12; "significant performance advantage"--- lol; http://www.energystar.gov/ia/partner...ide_062507.pdf
Gary
Dave Sal 11-05-2013 06:44 PM
Originally Posted by Gary in WA (Post 1262604)
Good job, guys!
Gary
That is interesting information. Wish I read this before I went back up in the attic to install the baffles yesterday. But, the job is done and I am sore all over from twisting and turning and bending and reaching. I have no intention of going back up in there in the near future. I'm getting too old for this stuff. :laughing:
I will definitely keep it in mind IF I ever install attic insulation again.
Gary in WA 11-06-2013 04:35 PM
Understand; old.... lol. Sorry I didn't see your post sooner. Glad others could help when they did!
Gary
