Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 01-10-2013, 02:14 PM   #1
Acoustic Seal around windows
I am currently in the process of putting up vapor barrier and was intenting to tuck tape the vapor barrier around the windows. I was told that according to code I have to apply acoustic seal as well. I can't find anything on line verifying that this is a requirement. Can anyone confirm?
lilly1379 is offline   Reply With Quote
Old 01-11-2013, 09:08 PM   #2
Exterior Construction
Windows on Wash's Avatar
Have you called your local code office?
Where is the home located?
Old 01-12-2013, 01:49 AM   #3
Lilly: first make sure a vapor barrier is a good idea in your climate. an air barrier/vapor RETARDER may be a better choice. the goo, like tremco acoustical sealant, is quite good stuff and will go a long way in minimizing leakage down the road. try to join you barrier product over studs so you can staple the layers tight, and goo between. code may prescribe that you do that on two adjacent studs; not sure on that.
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 08:49 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
Pella Windows - Serious Frost Issue snowman72 General Discussion 22 07-08-2011 01:39 AM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 07:32 PM
