8" Heat Duct Passing Through Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 01:27 PM   #1
8" heat duct passing through floor
We have an old house and when we replaced the hot air furnace with a new one, we had the contractor install a duct up thru the first floor to the second floor to get some heat to the second floor.
We have the duct framed out, ready to hang drywall. Before that is completed, we wanted to put some type of insulation around the duct where it passes through the floor. The floor is 1" thick oak with approx. 1" layer of concrete on top which was done to make a smooth surface to apply floor tile.
Fulton is offline   Reply With Quote
Old 09-22-2012, 01:46 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
Temps in the duct work shouldn't be that high where it would create an issue.
Seal the seams in the duct work so it isn't being lost between the floors.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Thinking about in floor heat... GottaFixIt Tiling, ceramics, marble 0 02-08-2012 01:50 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
