4kW From The Floor! - Insulation - DIY Chatroom Home Improvement Forum
Old 07-06-2013, 04:24 PM   #1
Rewards Points: 182
4kW from the floor!
So I bought me this nice $600 LG heat pump that's currently pumping heat out of my house. It handles a 20x20 room and this room is like 15x15. Except it doesn't work.
With 10.1SEER and a power draw of 1380W, I'm pulling 14000BTU/hr or about 4100kW out of the room. That vent outputs a ridiculous volume of insanely hot air. It works. But the room doesn't cool off.
I noticed then that the area above the porch, where the floor slopes and it feels like there's a hole under the carpet, is ridiculously hot. Ridiculously hot. I don't have a laser thermometer, but I've got a B&D TLD100 thermal leak detector coming... but I don't need it to know this is ridiculously hot.
Four kilowatts hot.
Holy crap, I'm drawing more heat through the floor than the massive friggin' AC unit can suck out of the room! Time to cut the floor out, level it (sister some joists), put in R14 insulation, news subfloor, and roll the carpet back over 'cause I can't afford the hardwood yet and don't want to do that.
Is this just a matter of cutting, folding, and packing rolled insulation? Should I pack the insulation as tight as I can force it in, or lay it down nice and fluffy? (this is a long standing argument between a colleague and I)
For now I've lain a big, fluffy comforter over the offending area. It helps.
If you can't explain why, then you don't know what you're talking about. I'll keep asking until I find someone who does.
bluefoxicy is offline   Reply With Quote
Old 07-07-2013, 09:24 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 872
Where is the home located?
Foam to the exterior will keep the moisture out of the assembly and help create the thermal break to isolate the framing as well.
Old 07-07-2013, 10:36 AM   #3
Rewards Points: 182
Baltimore, where it gets hot and humid and terrible.
Yeah maybe I should do some work above the porch then huh. It's just a huge amount of heat coming in.
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
