3/4" Styrofoam & House Wrap - Insulation - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 09:13 PM   #1
3/4" Styrofoam & House wrap
I have an old house & I am going to reside the house. I cant to put 3/4" styrofoam on & house wrap. Is that a good thing to do or not? Or what should I do? I have been reading online & there are so many different ideas. If it dose help I live in MN.
Bubbles17 is offline   Reply With Quote
Old 03-13-2013, 09:28 PM   #2
Rewards Points: 14,026
I'd stick with just the house wrap, reason being the foam will act as a vaper barrier.
You do not want moisture trapped in the walls.
Old 03-14-2013, 08:42 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
What type of foam is it?
EPS (typically referred to as Styrofoam) is very vapor open and does not create a vapor trap.
That being said, 0.75" of EPS has a minimal R-Value. In order to make the proper recommendation, we need to know what the wall construction is right now. Is it insulated, 2x4 or 2x6, any other details, etc.
Old 03-14-2013, 09:37 AM   #4
Also adding any thickness to the outside wall will cause a lot more work building out all the window and door trim before it can be wrapped.
Old 03-14-2013, 09:52 AM   #5
foamboard is a great choice energy wise. Your insulation in the existing walls is going to slow down your convection. The foamboard under the siding address your thermal bridging, which is an entirely different issue.
asinsulation is offline   Reply With Quote
Old 03-14-2013, 10:23 AM   #6
It is a 2x4 wall. & the styrofoam I was thinking of using is the bead board kind
Old 03-14-2013, 12:12 PM   #7
In this case, it can't hurt.
Old 03-16-2013, 10:21 PM   #8
Registered User
Rewards Points: 526
http://publicecodes.cyberregs.com/ic..._11_par002.htm
http://www.buildingscience.com/docum...r-requirements
http://www.buildingscience.com/docum...ting-sheathing
No poly sheeting under drywall.
Gary
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 10:32 AM
House wrap before the sheeting or after Marktrap Building & Construction 1 12-06-2012 09:23 PM
House wrap over insulating foam board or under?? getn2old Building & Construction 7 07-28-2010 10:53 PM
installing whole house filter on outside of house MikeInFL Plumbing 3 06-12-2010 04:47 PM
house wrap? Neil_K Building & Construction 3 12-22-2004 09:14 PM
