2x6 Rafter - Insulation - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 07:02 PM   #1
2x6 rafter
I have cattedral ciling with 2x6 rafter showing my zone code requaires R30 any suggestion will be very appreciative thank you Lorenzo.
lmiriel75 is offline   Reply With Quote
Old 10-29-2011, 09:37 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
How about some actual help. I understand the posts here can sometimes be short and without a lot of info and that half the people won't ever follow up after their question, but if you are going to take the time to post, post something helpful.
I think the OP is having a quandry about not having enough space to fit an R-30 in their rafter bay. Its indeed a problem not easily solved. I don't know of anything besides closed cell spray foam that would get you the required R-value in a 2x6 bay. If that's not feasable, you need to either fur down the rafters or use a higher density insulation like Roxul and put 2" XPS to the rafters which makes drywalling a little more difficult.
iminaquagmire is offline   Reply With Quote
Old 10-29-2011, 02:41 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Poly Iso in the rafter spaces that is cut to fit will give you the R-30 number and you would be best suited to have a rigid foam layer on the roof deck to isolate the thermal bridging of the studs.
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 11:26 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
Rafter Ties on Vaulted Ceiling timsgills Building & Construction 2 01-07-2010 04:02 PM
Moving Attic Access -- Same Rafter or Different ?? wrldruler Carpentry 1 10-19-2008 07:03 PM
