2" XPS Board - Insulation - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 11:08 AM   #1
2" XPS board
Hey guys I'm gonna start to insulate the basement walls next weekend and my question is what should I do about getting the 2" insulation behind my sewer pipes hung on the wall. I don't think I can fit it behind there, do I have any other options or should I just not worry about it and tuck up as close as I can. I only have about a half inch to work with back there.
Stellsbells is offline   Reply With Quote
Old 01-22-2012, 11:23 AM   #2
Rewards Points: 12,808
Go buy some 1/2 foam board.
Old 01-22-2012, 12:28 PM   #3
Ya think just do 1/2 " behind the pipe? Should be ok? Gonna finish basement over the next months
Old 01-22-2012, 03:12 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
How are the sewer pipes spaced?
Are they affixed to the wall, in the poured slab, etc?
If they are in the slab, 1/2 board is all you can get and if they are sewer lines (i.e. not supply lines) you should be fine.
Old 01-22-2012, 03:36 PM   #5
There hanging on the basement wall with metal banding. I live jut outside of buffalo by. It's not a slab house. Poured concrete foundation. You think the 1/2" board would be fine. Than I can just continue to use the 2" XPS board everywhere else
Old 01-22-2012, 08:41 PM   #6
Rewards Points: 660
What about leaving a 1/2" to 1" gap on each side of the pipe and using spray foam to fill the gap?
B
Beepster is offline   Reply With Quote
Old 01-22-2012, 10:58 PM   #7
Rewards Points: 864
That would work but I think folks are over-thinking it a bit. If it is a vertical sewer pipe, I would not worry too much about getting it perfectly insulated from the foundation wall. It should never freeze.
Old 01-23-2012, 12:13 AM   #8
Yeah it runs horizontal, it's about a 15 ft run of 3" PVC pipe. I maybe loosen te metal banding and try to squeeze the 1/2 " board behind it that's All. Thanks everyone for the help. I like havin the 2nd opinion.
Mike
Old 01-23-2012, 12:22 AM   #9
Registered User
Rewards Points: 4,912
Use a little foam compatible adhesive on them, to keep the air from the cold concrete wall:http://joneakes.com/jons-fixit-database/743
Gary
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Fascia board install - unlevel rafter tails giperbolic Roofing/Siding 3 01-18-2012 12:46 AM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 09:00 PM
Ridge Board Support Dilemma castlerock Building & Construction 2 01-06-2009 07:57 PM
