Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-01-2011, 10:02 AM   #31
Don't WANNA do it myself
mnp13's Avatar
1400 sq/ft of basically uninsulated attic
This picture was taken for the water damage, but you can see the spacing I was talking about in my last post.
The rafter board across the upper right of the picture goes into another board in this area (that backs up to the sole remaining in-the-wall chimney), but in the rest of the attic, they sit on top of the flat boards on top of the bricks. The roof rafters sit on top of the 2x12's.
1400 sq/ft of basically uninsulated attic-image-926017907.jpg
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 12-01-2011, 10:46 AM   #32
If the plan as I read it is to use the little cans of foam, not going to happen unless you have lots of money and time.
There is 0 need for all those layers. One layer of R-50 fiberglass would be all you need. Or have a pro come in with the proper equipment and spray foam the whole thing.
Old 12-01-2011, 01:15 PM   #33
mnp13's Avatar
Nope, DIY two part foam kit. Doing the entire 1400 sq feet in just foam is way out of my budget, whether I did it or paid someone to do it.
We're air sealing with the foam, then blowing the cellulose over it.
Michelle
Old 12-01-2011, 02:16 PM   #34
Exterior Construction
Windows on Wash's Avatar
Look at the gold insulation. You must have a Leprechaun in the attic.
Old 12-01-2011, 03:13 PM   #35
Originally Posted by gatorheel View Post
I don't want to overly alarm you, but you should assume that the vermiculite is contaminated with asbestos. It's not as bad as if you had high-friable asbestos pipe blankets, but since you don't have any insulation now you might want to consider having it completely cleaned up before you install new insulation. If most of it is already gone, I don't think it would be too expensive as it would just be a thorough HEPA vacuuming.
http://www.epa.gov/asbestos/pubs/verm.html
Matt
Note: If there is asbestos? In your vermiculite then it will do no harm, if you leave it alone.
Perry525 is offline   Reply With Quote
Old 12-01-2011, 04:33 PM   #36
mnp13's Avatar
Yup, I'm not worried about the possibility of asbestos. We're leaving it alone for the most part, and we keep handling to a minimum. :-)
Michelle
Old 12-01-2011, 04:36 PM   #37
mnp13's Avatar
lol
Don't I wish!!!
Michelle
Attic Insulation tim1218 Insulation 4 09-07-2011 11:18 AM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Wiring Protection for Accessible Attic BillyDIY Electrical 6 11-05-2009 09:44 PM
attic storage storageseeker Building & Construction 2 01-29-2009 09:02 AM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 08:10 AM
