14" OC Studs - Insulation - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 10:41 PM   #1
14" OC studs
Hello,
My studs in the bathroom range between 14" and 14.5" OC. While shopping for insulation, I've noticed that minimum widths start at 15". Could I squeeze that into my studs without affecting my R value? Or should I cut from a larger width?
enigmaingr is offline   Reply With Quote
Old 08-18-2011, 10:46 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Typically studs that are 16" o.c. (a common building practice) have about 14-1/4" to 14-1/2" spaces from stud to stud (in between the studs). Just depends on the actual size of the members and how sloppy the builder was.The insulation you mention should work.
XXX
Old 08-19-2011, 02:48 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Welcome to my attic - no two stud bays seem to be the same!
I squeezed in some of the batts, but I cut others. You don't want to squeeze it TOO much though.
CoconutPete is offline   Reply With Quote
Old 08-19-2011, 03:24 PM   #4
AGWhitehouse's Avatar
You can squeeze fiberglass batts a minimal amount before reducing the effective R-value. if you find the space more than a 1/2" skinnier than the width of the batt, you should cut it to fit. You cut fiberglass batts by compressing it with a cutting edge and slicing with a standard utility knife. If you don't compress the batt you'll have alot of trouble getting a clean cut.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-19-2011, 03:34 PM   #5
the Musigician
DangerMouse's Avatar
I used large scissors with excellent results (as well as my razor knife.)
Especially for cutting out outlet boxes.
DM
Old 08-22-2011, 08:16 AM   #6
DM
That's a great idea for those pesky outlet cuts!
The Following User Says Thank You to AGWhitehouse For This Useful Post:
DangerMouse (08-22-2011)
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 07:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 05:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 04:16 PM
