Will Newly Cut Down Maple Drain My Dream Garden Dry? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 01-19-2010, 05:27 PM   #1
Learning by Doing
Leah Frances's Avatar
Will newly cut down maple drain my dream garden dry?
I want to cut a new vegetable garden in my back yard (around 20x15 feet). We had yet another tree cut down this winter opening up a lot of daytime sunshine - a LARGE silver maple @ 7 feet in diameter.
I've been cautioned to wait a year or two before I try to put a garden here because the maple's roots will continue to draw water out of my hypothetical garden. Any truth to this?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-19-2010, 05:33 PM   #2
Civil Engineer
Rewards Points: 4,860
Your hypothetical tree will draw hypothetical water out of your hypothetical garden. So perhaps you should hypothetically worry. Back in the real world, relax, the leaves are what transpire water, once the leaves are gone (you cut down the tree), there will be no transpiration, no water draw, no problems, except the roots will not rot for several years.
Old 01-19-2010, 05:50 PM   #3
I cut a Maple down in the back that was maybe 12" or so across
Spring came & that thing was pumping "something" out of the stump
Like what I almost think would come out if you tapped the tree for syrup
It took quite a while for it to stop, so the roots will still draw water/moisture
It was 5 years ago..so can't remember how long it lasted
But it really wasn't that long (ie years), and it was early Spring when it started
So maybe a month or two at the most
Did you have the stump ground down on this one ?
Old 01-19-2010, 05:59 PM   #4
Learning by Doing
Our tree guy did level the top off nicely for future 'planter' use....
For reference the fence is 5 ft. And the property line runs through the stump...
Old 01-19-2010, 06:18 PM   #5
Yeah...I'd fill it with dirt & plant stuff
Maybe need to fill in on one side to hold dirt in
There is a "vine" that grows out & is used in hanging planters
It only gets about 16-24" long. can't remember the name
That would be good around the edge of the trunk
Then flowers on the inside
Putting plastic in would help hold moisture in the trunk area
ie - line the inside with a big piece of plastic before you fill with dirt
Another trick is to cut the tops off 2l bottles & bury them- filled with dirt
They will hold rainwater longer & roots will grow into them
Old 01-19-2010, 06:20 PM   #6
Tom Struble's Avatar
Rewards Points: 2,002
vinca
Tom Struble is offline   Reply With Quote
Old 01-19-2010, 07:06 PM   #7
Learning by Doing
I was thinking vinca and maybe a hydrangea. I've also been contemplating a decorative grass.
Old 01-26-2010, 02:37 AM   #8
Exotic NooB
Order some top soil and build a raised bed around the stump. Use the edge of the stump to support ceramic planters or giant pots that you place at different levels to create a multi level garden...
If you have to wait a couple of years to plant in that spot, get some straw bales and surround the entire area you want to plant in with straw, leaves, grass clippings, pine needles, newspaper, cardboard, and other compostable materials. You can make a pretty good cold composting pile and by the time two year is up you will have real nice soil and it might speed up the decomposition of the tree roots by keeping the soil warm in the winter with the composting process.
If you get enough straw bales, you can create some sort of retaining wall out of the bales to keep everything neat and tidy around the tree stump.
inlikeflint is offline   Reply With Quote
Old 01-26-2010, 11:50 AM   #9
Learning by Doing
I think I've decided that I am not going to do the garden this year, but I think I will try the cold composting idea with the hay bales. I may try that in the fall with my leaf and grass clippings.
I think I will also set the chickens loose in this area for the summer to pick bugs and fertilize.
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
