Why Did This Happen? - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 11-20-2013, 07:05 PM   #1
My Landscape Mulching Project
I am a ninth grader doing a science fair project. I decided to test some landscape coverings to see which ones blocked out the most weeds. I planted 16 weeds in each section and then put the landscape coverings over them to see which one would have the most weeds left over at the end. These are the results.
Control: 28 weeds
Clear Mulch (cut up gatorade bottles): 19 weeds
Rubber Mulch: 4
Pine Needles: 3
Black Mulch: 1
Granite Gravel: 0
Sand: 2
Weed Fabric: 2
I am a little confused on a couple of things.
What caused the black mulch to be so effective? It retains a lot of moisture, so would presume it steals some of the weeds' water, but it also keeps them cool.
Sand blocks out all sunlight, so why would there be any growth there? It is basically the same as gravel except for the particle size, so it should do much better than gravel.
I know that plants sense sunlight and grow towards it. Is this why the weeds in the weed fabric skirted around the fabric and came up out of the side?
Keep in mind that I planted 16 weeds in a 2x8 formation in a 11.5"x28" space. There were about 2" thickness of the materials, except for weed fabric (we put three layers of that). This was done in South Florida (Zone 10B).
Thank you!
Dino-Rabbit is offline   Reply With Quote
Old 11-21-2013, 05:01 AM   #2
DIY staff
Rewards Points: 7,174
Bear in mind that your experiment /sampling is rather small--unless you do several beds of each type of mulch---you must factor in the possibility that some plants just die----ask any gardener.
it is possible that the black mulch has a higher surface temperature and hurts the plants---
Old 11-21-2013, 05:39 AM   #3
PoleCat's Avatar
Rewards Points: 1,646
You have bitten off quite a big task. Particularly in southern Florida where you have multiple overlapping growing seasons. You may need to narrow the scope of your experiment.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is online now   Reply With Quote
Old 11-21-2013, 05:55 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,452
As with any experiment, you have to repeat the same test 2 more times to see if you get similar results.....only then can you narrow down the cause.
ddawg16 is online now   Reply With Quote
Old 11-26-2013, 03:28 PM   #5
Agreeing with o'mike, the black mulch can get very hot in direct sunlight. Especially if it's sheet plastic? Not sure what you specifically mean by black mulch.
kenearlg is offline   Reply With Quote
Tags
mulch , results , sand , sunlight , weed
what will happen jmans8666 Electrical 24 05-13-2011 03:10 PM
What would happen if... Improper Generator installation ? Steven Jackson Electrical 26 12-03-2009 08:52 PM
Does anyone know what happen to my plants?? just_another_guy Landscaping & Lawn Care 5 06-30-2009 07:15 PM
Run submerged waterfall pump without water, what will happen herbolaryo Electrical 2 08-15-2007 06:03 PM
What will Happen if I pmb003 HVAC 2 09-21-2005 06:55 AM
