Waterproof A Wood Planter - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 04-09-2013, 01:45 PM   #1
waterproof a wood planter
what do you use to waterproof pine wood planter
jarrrrhed is offline   Reply With Quote
Old 04-09-2013, 05:44 PM   #2
Bill Kearney
Rewards Points: 1,174
water from where, inside or out of it?
wkearney99 is offline   Reply With Quote
Old 04-09-2013, 05:51 PM   #3
Rewards Points: 13,712
Pressure treated, unpressure treated?
Old 04-10-2013, 08:54 AM   #4
Too Short? Cut it Again!
They sell molded plastic liners in just about any size and configuration you can imagine. Your real, not box store nursery or even your florist should be able to order exactly what you need if you cannot find it.
The problem with trying to "waterproof" wood containers is you can keep them from breathing and expanding and contracting on one side. You end up causing more harm than good. Obviously you may want to stain or prime and paint the exteriors. Some sort of rust inhibitor on the fasteners is not a bad idea.
Old 04-10-2013, 09:01 AM   #5
If I get stuck making a planter I first find the plastic liner that has been suggested. I make the outside wooden box the sive so the liner will just slip into it and rest on the top of it.
I also do not install a bottom in the planter, since that the first thing that's going to rot out.
If the planters going to be sitting in direct contact with any surface I add PVC lumber stand off's so the wood will dry out.
I also would never have used pine.
Cypruss, cedar, IPE, even fur would have been better.
user1007 (04-10-2013)
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 05:20 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 03:14 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
