Tree Trunk Damage - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-21-2011, 02:33 PM   #1
Rewards Points: 101
Tree trunk damage
I have a couple of plum trees that were planted about 2 years ago that I noticed have some trunk damage after this winter. We had a long winter in Reno, NV this year.
I initially thought it might be bug damage, maybe rabbit or something too, or just damage from the cold weather?
Here is a couple pictures of the trunks. The trees did ok this spring, flowered a bit less than i would have expected, but now have approriate leaves.
Is there anything I should do to the trunks to help repair them? Prevent it from happening again?
mikereno1 is offline   Reply With Quote
Old 07-21-2011, 02:48 PM   #2
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
I am absolutely not an arborist, but it looks like that damage is all close to the ground - where a small animal could have caused it. Is it also up higher on the trunk?
A lot of people put a piece of corrugated plastic pipe around the bottom of the tree to protect it:
(Image found on google)
hyunelan2 is offline   Reply With Quote
Old 07-22-2011, 04:18 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
I do believe you are correct
Old 07-22-2011, 04:19 PM   #4
Too Short? Cut it Again!
Grew up in orchard country and I think, given your climate, you got some bark vulnerability from the weather and something chewing away at what was exposed.
I would think about protecting that trunk as shown but might also consider a spray to keep insects out until there is some healing. You might call the University of Nevada ag extension, if anybody answers the phone, for recommendations.
Years ago when I practiced landscape design the battle about whether to seal open wounds and pruning cuts was starting. I do not know how that has ended up where you are but you might consider some tree tar on a wound like that? Do you have a real nursery near you can ask if no helpline is availed by the University or State?
Good news? Plums are usually very sturdy. I had a purple barked flowering one in the front yard of my home in Northern California. Weather and creatures would try to get it but it was tough.
Old 09-03-2011, 05:41 PM   #5
LHO
Looks like buck rutting -- only solution is venison.
LHO is offline   Reply With Quote
Old 09-04-2011, 03:09 AM   #6
chrisn's Avatar
Rewards Points: 396
I would wait for a deer a little bigger than a rabbit myself
Old 09-04-2011, 07:34 AM   #7
the Musigician
DangerMouse's Avatar
I'm with LHO. Deer rutting.
If it was chewed by small critter, this picture could not be explained.
DM
Old 09-04-2011, 10:05 AM   #8
LHO
Here is a photo of a poor maple tree that gets revisited every year. We have tried the corrugated drain pipe. Look what he did three nights ago (this was not the perforated type). You should have heard all the terrible racket.
Old 09-04-2011, 10:08 AM   #9
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 844
You should try to trim off the loose bark and clean up the edges with a clean knife to deny bugs and such any place to hide. Remove as little intact bark as you can. There are trunk protectors made from fine mesh wire that would let air get at the wound which will help the tree harden off the damage.
It is a serious wound but plums are pretty tough. Make sure it gets enough water and spray for leaf pests if necessary. The tree will be stressed enough recovering from the wound, you want to keep all the other stressors in check.
Thunder Chicken is offline   Reply With Quote
Old 09-04-2011, 10:10 AM   #10
the Musigician
Isn't there a brush on tar-like substance you can get to help seal it up?
DM
Old 09-04-2011, 12:46 PM   #11
Rewards Points: 844
DM
Pruning sealer doesn't help the tree harden off the wound, and the solvents may actually cause more damage to the cambium.
If the tree can heal it will.
Old 09-04-2011, 04:08 PM   #12
chrisn's Avatar
Rewards Points: 396
very ture, the sealer is an old wives tale
Old 02-07-2013, 10:49 PM   #13
they are right you should do the same cover the damaged area by pipe or some thing and is still you tree looks a bit ill or getting week then you should any Landscaping service company.
paulsmith544 is offline   Reply With Quote
Old 02-08-2013, 04:06 AM   #14
chrisn's Avatar
Rewards Points: 396
Do you realize you are digging up posts that are YEARS old?
Last edited by TheEplumber; 03-19-2013 at 10:31 AM. Reason: remove link from quote
Old 03-18-2013, 10:25 PM   #15
Def the right thing to do. Anything to cover the bottom and protect it from small animals. Also a piece of chain link fence rapped around it will keep it safe too.
fixerupper10 is offline   Reply With Quote
Treating a Tree rightit Pest Control 3 06-05-2011 08:56 PM
Extending deck around a tree jcgoldie Building & Construction 2 02-15-2011 05:20 PM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 02:15 AM
Damage from tree on power lines Jeremy Hillary Boob, PhD Electrical 81 01-01-2010 04:12 PM
Need some advice on buying home termite & water damage. Mr Heshup General DIY Discussions 1 03-29-2009 03:06 PM
