Storage Shed Retainer Wall - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 04-03-2010, 07:07 PM   #1
Smile
I am getting a new shed and the spot I choose is unlevel. I already cleared the ground to make it level. The problem is the one corner is 3 feet below grade. I was wondering if I could just fill it in with stone and place a barrier over the dirt on the hillside to protect the shed walls. The exterior of the shed is vinyl siding.
cmlatch is offline   Reply With Quote
Old 04-03-2010, 07:35 PM   #2
Not a good idea to bury a wood frame 3' below ground
Old 04-03-2010, 07:36 PM   #3
put piers on the low end and divert h2o on upper side
The older I get the better I was
Old 04-03-2010, 07:41 PM   #4
What would you suggest then...A retainer wall built with 6x6 or stone?
Old 04-03-2010, 07:44 PM   #5
Solution depends upon the landscape
I'd probably split the depths & raise the 3' end up & build up the other end
Then maybe landscape timbers
Any pics ?
Base for Lifetime (plastic) storage shed proofer Building & Construction 13 07-03-2015 06:09 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 02:30 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
