-   Gardening Forum (http://www.diychatroom.com/f102/)
-   -   Sprinklers for garden bed (http://www.diychatroom.com/f102/sprinklers-garden-bed-181988/)
GRFagan 06-17-2013 01:51 PM
I am wondering what is the best type of sprinkler head to use in my garden bed. I have planted small bushes, but currently have the type that is for watering grass. I don't have any ground cover plants, just the bushes with wood mulch covering the rest. The bushes are spaced about 2-3 feet apart. Thank you ahead of time for your help.
user1007 06-17-2013 05:05 PM
I would switch to drip irrigation and water in gallons per hour rather than gallons per minute. Unlike the spray heads you have, drip will put water only where you want it. It is easy to install and inexpensive.
I would work with simple self-cleaning, self-compensating emitters in the 1-4 gph range. You will not be able to have the drip system on the same circuit with lawn sprinklers. One drawback to drip is that the emitters have to be on the surface but you can bury the pipe somewhat. A few older automatic valves do not work with drip because of the low flow rate so you might need a new one for the drip system if yours fall into that category. Some timers do not water long enough per circuit either.
Check out some online place like The Drip Store for the best options for emitters. Or if there is a real irrigation supplier near you, they will be able to set you up.
henrylarry6 06-18-2013 09:23 AM
For sprinkler, visit amazon.com there you will find n number of sprinklers for your garden bed.
