Sprinkler Hose Leaks - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-08-2011, 08:38 AM   #1
LGF
Question
Sprinkler hose leaks
Periodically, I find the ground wet from an underground sprinkler hose which has sprouted a pinhole leak. I have to dig up the hose and splice a new section of hose in which is a major pain in the neck. The leaks appear anywhere in the line and no stones or roots are near the leak. Is there a reason this happens? The hose is standard black plastic hose that sprinkler companies used when the system was installed and it is fairly old. Still, I don't see a reason for pinhole leaks to happen unless the hose was substandard to begin with. Is there any way to avoid this? I'm a newbie here so please advise what I can do to prevent this from happening regularly. Thanks.
LGF is offline   Reply With Quote
Old 07-08-2011, 06:56 PM   #2
Too Short? Cut it Again!
Where are you?
And how old is old? The pipe, possibly flex polyethelene, may have just lived out its life and you may have to bite the bullet and replace it. Do you have a piece of it with markings left? Or can you describe thickness and feel when you squeeze it? Wall thickness?
Does it freeze where you are? Was it buried deep enough to avoid the freeze? Do you blow your irrigation system free of water at the end of each season?
Old 07-12-2011, 07:26 AM   #3
LGF
Thanks for getting back to me. I live in NJ to answer your first question. It gets cold here in winter but usually just below freezing. The hose in question was a good 10" deep. Yes, I do blow the lines out each autumn and shut the system down. Wall thickness seems to be about 1/16" and I replace it each time with the same hose from a sprinkler supply so my guess is that it has a life as you suggest. I believe the system is 20 years old. I just don't understand why a small slit develops and becomes a pinhole leak. Any further thoughts?
Old 07-16-2011, 12:35 PM   #4
Polyethelene, I am guessing, pipe just aged. Replace it. If you do not have major freeze issues use SCH 40 or even 80 PVC if you want to be safe.
Frozen outside faucet leaks -> Hose left attached k6trouble Plumbing 13 07-01-2013 11:29 AM
Hose Bib Sprinkler Timers WirelessG Landscaping & Lawn Care 0 06-02-2011 07:55 PM
Outside spigot leaks into crawlspace only with hose attached amandat37 Plumbing 1 04-12-2011 06:32 AM
sprinkler valve leaks deck hand Landscaping & Lawn Care 3 06-20-2008 08:36 PM
How to Look for Leaks in Sprinkler System herbolaryo Plumbing 8 06-05-2007 09:29 PM
