Shed Install In Wet Backyard - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-17-2013, 08:45 AM   #1
Question
Shed install in wet backyard
I bought the Suncast 98-Cubic Foot Horizontal Blowmolded Shed (Amazon link with pictures) to install in my backyard. My problem or hesitation is that the ground in my backyard gets soaking wet when it rains a lot.
I'm on an end unit home and right next to my house is a big open space that consists of mostly a mound of dirt where not much grass grows. I suspect they placed things there like excess cement and such when the development was first built. Water flows right down from that mound into my backyard, and it doesn't really go anywhere from there. And the back of my backyard slopes up to a line of trees behind my fence, so I can't put the shed there without excavating some dirt and building a retaining wall of some sort (which I don't want to do).
My question is as follows: will I have a problem if I place my shed along my fence on the side of my backyard closest to this open space? Can I just dig under the place I want to put the shed and place several inches of rocks for drainage, and then place the shed on top of that? Or will it sink or get muddy when it rains?
What would you recommend as the best installation procedure for my situation?
Thanks a lot. I hope someone can help me as the longer the shed stays boxed up in my basement, the longer my cat has to get to it.
jasonruns is offline   Reply With Quote
Old 05-17-2013, 08:59 AM   #2
Rewards Points: 13,300
Set post and a platform with the top of it at least 6" up off the ground.
Those plastic sheds are near imposable to keep level enough to have the doors stay plumb and will tip over or blow apart in a stong wind so having it attached to something solid will give it 1/2 a chance.
Old 05-17-2013, 09:07 AM   #3
How would you set the posts? Could you do it without concrete? And would you still put rocks under the shed even if the platform was 6" off the ground?
Tags
drainage problem , shed , sheds
Help in foundation for vinyl shed on existing pad EmmaSurf Building & Construction 2 11-08-2012 10:52 AM
Shed subpanel BrandonD Electrical 21 10-14-2012 01:06 PM
Keeping a small metal shed dry. adam macross General DIY Discussions 3 10-10-2012 02:43 PM
How should I insulate my shed? kbizzle Building & Construction 19 06-21-2010 08:50 AM
Shed Wiring bcdal Electrical 12 03-26-2008 05:51 PM
