retaining wall and run off
Thanks for reading this hopefully HELPING ME...sure can use it!
Had a retaining wall built and they banked it after and put steps down the big hill. the problem is that I have rain run off...destroying and taking out the steps. The wall is built straigth across and then a L shape going back towards the house . Only two blocks...on each end...so the rain is running down the wall into the steps. I told the company they need to go out more so the run-off goes down towards the house and then down the hill. Am I correct. Single mom with really no clue but i think that would be the rigth thing to do??? what can I tell them to do...they seem to think it's ok...but it's not..washed away the steps twice....or every time it rains. HELP...I have pics maybe that will help?? Geri-lyn |
How tall is the wall?
Sounds like they did not install the proper drainage at the top of the wall. There should be either a swale cut at the top of the wall and carring the water AWAY from your house or some type of underdrain that drains away from the house. |
Exactly, unless the wall is less than 4' high, then they may not have done drainage at all. |
Yes, drainage is really important, or water will build up behind the wall, underground, and eventually the water pressure will cause the wall to buckle. Right here in Kansas City, about a year ago, we had a highway overpass collapse because of this same problem, but they called it a "sinkhole" so your average person wouldn't know it was actually "poorly engineered."
I assume this is a concrete wall? It should have holes in the bottom with pipes visible inside the holes, to let water out at the bottom part. If you don't, you have a BIG problem. |
| All times are GMT -4. The time now is 05:52 PM. |
