Re Leveling Patio - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 12-22-2011, 04:23 AM   #1
Re leveling patio
Hi I had a blue stone patio laid a year ago. The pavers were laid on road base and a thick layer of cement/concrete or the pavers are cemented down. As I've started using the garden I've noticed that the patio was not laid properly, it is not level.
I would like to know if this can be fixed without ruining the pavers?
Charmain is offline   Reply With Quote
Old 12-27-2011, 06:43 PM   #2
Too Short? Cut it Again!
Obviously you have to get under the pavers to fix the grade/level problem. If they are somehow "glued" down to a subtrate you may end up breaking them trying to get them loose. Sorry to bring such news to you. If they are on on a layer of mortar or even a Quickset mix you should, with care, be able to get under them with a long masonry type flat spade.
How big are the pavers? My mind's eye visualizes large ones.
This seems like a relatively new installation from what you describe. What happened in such a short time to take your patio off level? Was the soil under the patio not compacted properly or something? Are there drainage issue like from a misguided gutter downspout?
Do address the infrastructure as to what has gone wrong before anything else.
Leveling patio space jlatour Landscaping & Lawn Care 3 06-01-2011 08:25 AM
Patio Cracked & Sinking silvabul Building & Construction 3 05-04-2011 09:53 AM
Will pay for patio advice! :) DirkPitt Landscaping & Lawn Care 6 07-31-2009 02:35 PM
Brick Patio - leveling Patcho Landscaping & Lawn Care 1 04-24-2007 01:43 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
