Need Tips For Flower Garden - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 06-27-2012, 07:57 PM   #1
Rewards Points: 590
Need tips for flower garden
I promised my wife that I would fix up our flower garden around the front of the house for her birthday. I have been slowly working on it since April when I get time. It was full of lava rocks which we both hated so I dug them all out. I have now bought 82 border block things (still not enough for one side of the house!!!). Them things are heavy and took a while to put down in a straight line so I am looking for a way to help prevent them from moving around a lot. I am sure I will hit then with the mower.
Also, how do you stop the damn weeds from taking over!! I know nothing about gardening btw.
Here's a pic of the side I put the blocks down do far. I am going to add dirt and mulch when I have money and time.
nikeman is offline   Reply With Quote
Old 06-27-2012, 08:15 PM   #2
Rewards Points: 13,712
A single layer just sitting the ground is just not going to stay in place for long and the weeds will just go under them and through the spaces.
Really needed to rototill out the area where the blocks are going, rake out the grass and weeds and back fill with crush and run or some compactable sand.
(A Mantis tiller works perfect for this)
Each block needs to be set level, I'd split the first one in the bottom row in half with a brick chisle, that way the second row will over lap the joints.
Old 06-27-2012, 08:40 PM   #3
Rewards Points: 104
I agree with Joe; you need a level surface, free of grass, weeds, soil clumps, etc., so would do as he suggested. Before you start, decide at what elevation you want the top of the stones, and how far off of the foundation that you want them; the curves you can obviously free hand, unless you want a perfect radius, but you probably want them straight along the house. Set a stake at each end, an equal distance from the foundation, and a foot or two beyond where you want to run the stones. Now, you can use the bottom of your siding as a benchmark, to determine how far below that you want the stones, and then use a 4' level to extend that mark to each stake. Remember that you want your finish grade in the beds to slope away from the house, a minimum of about 1/8" per foot. Run a string from the mark on one stake to the mark on the other, and you have both a straight line, and an elevation. Now, mowing, then trimming along the stones, can be a pain, so, going back to planning, you need to decide whether you want them at or above grade. Personally, I prefer a free running mulch bed, no edge, which requires a little bit of dressing once in a while, but more than makes up for that in time spent mowing and trimming. But, that wasn't one of your questions, so back to task. While you are doing this, buy a few elbows and enough downspout to extend them out, at least 3-4' from the house, away from your foundation. Also, going back to the mulch thing, I would plan for at least 2-3" of that inside the stones, while you are working out elevations, as it will help hold moisturte for your flowers. Keep in mind that nice, neat, appealing beds do not happen my accident, and a little additional planning and effort on the front end will pay huge dividends in the future.
Old 06-27-2012, 08:50 PM   #4
I'd also get rid of those shrubs that are right up againt the porch.
Old 06-27-2012, 09:34 PM   #5
Rewards Points: 590
Thanks guys. She likes the look of the block border so I'll have to just trim around it when I mow. We had wooden posts laid all the way around the garden and I am using those as my height and distance guide. The gutters drain down into plastic tubes that go under ground and drain somewhere that I have yet to locate. I do have a drainage issue where over the years water has overflowed the gutters in one section and eroded a lot of dirt away leaving a slight ditch. I didn't notice it until I shoveled out all the lava rocks in that area and have now filled it in with dirt. Luckily it's in front of the porch and not right up against the foundation.
Old 07-31-2012, 06:15 PM   #6
Rewards Points: 590
Update:
I had a little time to work on this again. What do the experts think of what I'v done so far?
Old 08-02-2012, 10:54 AM   #7
Rewards Points: 590
Should I mortar the top layer?
Old 08-02-2012, 11:36 AM   #8
No need to.
You really should use a couple of stakes and pull a string to keep it straight.
Old 08-02-2012, 12:51 PM   #9
Rewards Points: 590
That's a good idea. I kept putting down a couple blocks and then making sure I was going in a straight line. That's what was taking so long!! For the rest I will use a string.
Old 08-05-2012, 07:39 PM   #10
Rewards Points: 590
One side done minus mulch.
Old 08-05-2012, 07:50 PM   #11
Happy Belated Birthday Mrs. Nikeman.
Hosta's and Hydragea. Looks great
creeper is offline   Reply With Quote
Old 08-05-2012, 08:00 PM   #12
Rewards Points: 590
The hydrangea is the newest plant and I actually just sprayed it with round-up on accident because the sprayer is messed up apparently! It wasn't much so hopefully it survives.
Old 08-05-2012, 08:05 PM   #13
Dang. I hope you hosed it off in a hurry. You will know in a day or two
Old 08-05-2012, 08:15 PM   #14
Rewards Points: 590
While we are on the topic of round-up.... I bought some ortho groundclear because it says it will last a year. Upon research it appears this stuff is pretty potent and I even read a story of someone who killed a few 40' pine trees and had to have them cut down. Is this true? I'm not using it in my flower bed now obviously but killing full grown trees.... Really? I would like to spray my walkway and drive way but the walkway is beside the flowerbed and their is a huge tree actually touching the driveway. The way people talk about it I don't want to use it anywhere in my yard since there are so many large trees.
Old 08-05-2012, 08:45 PM   #15
Where I live a product like that would not be avaliable for purchase for the average homeowner. I've actually never heard of it. We can't get weed'n feed products. Round up in small amounts only. The jugs are kept locked up.
Someone else will be around the corner shortly
Small pond/water garden in desert on the cheap? (lots of questions) tamtrible Landscaping & Lawn Care 0 09-14-2011 12:57 PM
New lawn + garden - garden is now a swamp Frozinite Landscaping & Lawn Care 8 09-15-2010 07:23 PM
Spring in the Veggie Garden Bushman Gardening Forum 0 05-02-2010 07:03 AM
Underground water line to garden? NateHanson Landscaping & Lawn Care 13 06-11-2009 07:39 AM
Planning a garden tips Stillwerkin Landscaping & Lawn Care 0 12-28-2008 11:41 AM
