Malibu Landscape Lights - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-23-2014, 06:59 PM   #1
Rewards Points: 30
I have a set of Malibu Low Voltage landscape lights. They are old but look very nice and I prefer them over the newer solar lights. However, they are difficult to maintain. Perhaps some of you have learned some tips over the years that you can offer to me? A burned-out bulb is an easy fix. But often they go out because they lost good contact with the power. That's not so easy to fix. You must dig-up the contact leads (named "fast-lock II") to clean the metal points that score the wire coating (not easy - you kinda need three hands!) And sometimes the problem is at the bulb socket. You have to wiggle the bulb to get good contact, or bend the prongs for tighter fit. What always happens is you get the bulb to light, but as you attempt to place it back into the ground it goes out and you have to try to figure out where the problem is. Sometimes the troubleshooting causes the bulb to blow but you don't know it blew and you try wiggling and jiggling to get it to light but it won't until you use a new bulb! Has anyone found some easier ways to wire / repair these sets? Is it possible to "hardwire" the entire system and bypass all the contact devices?
Steveromo is offline   Reply With Quote
Old 07-23-2014, 08:57 PM   #2
Rewards Points: 1,062
I dumped mine after a few years- bulbs are proprietary, meaning $$$$$$. Like the 49$ printer that uses $30 ink cartriges. Junk. Dump them. They never seated right down in the 2 contacts.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-16-2014, 01:01 PM   #3
I love my malibu lights i have had them working nightly for over ten years now they were difficult to maintain 2 years after i installed them, but this is what i did 2 years ago no problems since. First i tried to spray contact cleaner but really the copper terminals need to be cleaned up with a wire brush or steel wool make sure the power is off when you do as it will spark they are close to + -, then i bought some DiElectric grease off ebay it keeps the contacts from getting moisture on them from dew and hence keeps the contact continous. I have switched to 12v LEDs bright white that i soldered up myself i bought some ready to go ones on ebay but the resistor wattage was too low and they only lasted like a night, i ended up running the same resistor wattage that i use in the car 470 ohm @ 1 watt +/- 5% i installed these now 6 months ago and they are still working well they aren't bright but i just have them as accent lighting if you need them to actually illuminate a path then look for the super bright leds. I have added spot lights recently to my light sets since the leds are low consumption the transformer will not feel the additional load, I'm running 10 lights on an 8 light setup.
humpty111 is offline   Reply With Quote
Old 08-16-2014, 01:05 PM   #4
By the way the auto parts has a small pouch called bulb grease same stuff as what i bought on ebay no shipping and no waiting.
Old 07-31-2015, 03:32 PM   #5
Rewards Points: 30
Revisiting this subject with a follow up. A great deal of the frustration with these lights are when a light is out not because a bulb blew but because the contacts are bad at the power line in the ground. You dig up the connectors, pry them apart, clean them up, then reattach and still dark! Or sometimes they light but go out as you place it back in the ground. I wish I could "hard-wire" the contacts directly into the power line. Can this be done?
Old 07-31-2015, 04:24 PM   #6
Rewards Points: 3,707
I can't think of any reason 'why not'. You will need a waterproof connection. For LV liquid tape may be enough.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
landscape lights wiring plan tarheelblue Electrical 0 12-02-2012 02:35 PM
Lights still dimming and flickerin Keisha34 Electrical 18 06-09-2012 12:14 AM
Dimming and Flickering lights in home Keisha34 Electrical 34 06-05-2012 03:22 PM
New lights in basement CooperChloe Electrical 11 01-11-2009 12:22 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
