Landscape Fabric Pegs - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 07-21-2014, 01:23 PM   #1
What can I use to hold down landscape fabric ? The pegs made specifically for this are $5 for 20 --- too expensive.
Anyone have any ideas ? Don't want to use nails.
theMezz is offline   Reply With Quote
Old 07-21-2014, 01:26 PM   #2
Rewards Points: 12,818
Best thing you can do is not use any fabric.
Weeds will still just grow through it an be harder to remove when they do.
One of the reasons to make sure you use at least 4"'s of mulch and add some Preen to help stop new weeds from growing.
Old 07-21-2014, 01:35 PM   #3
Rewards Points: 1,010
Do you need the pegs in permanently or just to hold it in place while you set the mulch? If it's temporary, I used rocks or pieces of brick until most of the mulch was down. If it's permanent, $5 for a bag of 20 pegs really isn't too bad.
spaceman spif is offline   Reply With Quote
Old 07-21-2014, 02:18 PM   #4
I installed a drainage ditch and it's 90% full of stones... next I want to put landscape fabric on top and then put top soil on top of that...
I wanted to use something to hold the fabric in place to stop the dirt from going into the stone
thank you
Old 07-21-2014, 05:36 PM   #5
Rewards Points: 6
Get a spool of thick wire. Cut it into 8 inch lengths and bend them into a tight U shape...like a staple.
Dan
djlandkpl is online now   Reply With Quote
Old 07-21-2014, 05:41 PM   #6
thanks- I will try the wire...
just didn't want something that may come up later and I'd fling at someone in the lawnmower in the future..
but I think the wire will be ok .. I think
Old 07-21-2014, 06:01 PM   #7
That just makes no since to me.
How is grass going to take root and stay put on a slope with just a few inches of top soil?
First bad storm and the top soil and grass seed is all going to run down to the middle of the ditch.
Really want to add to the amount of weed whacking and weed pulling on that slope?
Old 01-26-2015, 11:03 AM   #8
Rewards Points: 28
Fabric pecs
Cut old wire coathangers to size
Thebarn134 is offline   Reply With Quote
Old 01-27-2015, 12:36 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 338
thank you
Ayuh,.... Yer over-thinkin' it,....
Spread the fabric, then spread the top dirt,...
The top dirt will hold the fabric in place, much better than stakes,....
Old 01-27-2015, 07:25 PM   #10
Rewards Points: 28
yer underthinkin it
The dirt is under the fabric, mulch goes on top, when your doin a big job it keeps it in place while ya work
Old 01-28-2015, 09:16 AM   #11
Rewards Points: 66
I second the bent wire idea. If you are worried about dangers with a mower, you could also use wood staves to pin the fabric down. Either you can split and sharpen the tips to pierce the fabric and ground or you and sharpen a single top and ensure that the top somehow will prevent the fabric from pulling through.
arvanlaar is offline   Reply With Quote
Old 01-30-2015, 08:43 PM   #12
Rewards Points: 118
If you buy them in a bigger package at HD they are $10/100:
http://www.homedepot.com/p/Unbranded...00-6/204268232
ChuckF. is offline   Reply With Quote
Landscape fabric under gravel driveway? jpsmith Landscaping & Lawn Care 15 12-09-2012 10:24 PM
Cutting landscape fabric phil74501 Landscaping & Lawn Care 14 04-23-2012 07:46 AM
Retaining Wall Geogrid + landscape fabric? teamcampreder Landscaping & Lawn Care 5 03-26-2012 07:03 PM
Landscape Fabric rjordan393 Landscaping & Lawn Care 3 03-22-2011 07:17 PM
Alternatives to landscape fabric? ricksample Landscaping & Lawn Care 10 02-01-2011 04:18 PM
