Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 02-16-2013, 02:35 PM   #1
How to measure for backyard elevations
I've got a huge backyard that I know has low spots, high spots and drainage issues.
What's the best way to determine them?
I've attached a few photos from different views.
How to measure for backyard elevations-image-41823703.jpg   How to measure for backyard elevations-image-3194411257.jpg   How to measure for backyard elevations-image-2373535887.jpg
butterkups is offline   Reply With Quote
Old 02-16-2013, 05:51 PM   #2
Master General ReEngineer
Bondo's Avatar
Ayuh,.... There's a Few options,....
Simplest is a clear hose, fulla water....
A Sight Level, or better yet, a Lazer Level can be rented at most rental shops,...
Once ya set the corner pins, 'n establish the high point, 'n low point,....
Lotsa string-lines, 'n pins gives ya something to work from....
or a Good operator on a dozer could probably grade it from the seat...
String-lines are the Key though...
Old 03-15-2013, 10:25 PM   #3
you can go old school
http://explorable.com/roman-roads
redman88 is offline   Reply With Quote
Old 03-16-2013, 11:35 PM   #4
Redman is correct.
You should use a Cuba Libra.
cleveman is offline   Reply With Quote
Switch to Trex Elevations jensor Building & Construction 18 07-05-2012 08:03 AM
What is the MOST ACCURATE way to measure for replacement windows? Evil Scotsman General Discussion 0 05-18-2010 11:06 PM
Suspended Ceiling - measure up or down? Woodcutter Remodeling 8 02-28-2009 06:53 AM
How to measure for new pre-hung interior doors jencampo Carpentry 3 03-25-2008 01:49 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
