How To Get Of These Weeds - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 06-05-2014, 12:01 AM   #1
How to get of these weeds
They are located in the soil next to my home.
dinosaur1 is offline   Reply With Quote
Old 06-05-2014, 03:41 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
pull em out
Old 06-05-2014, 07:17 AM   #3
Originally Posted by chrisn
pull em out
There are a ton and they are all around my home.
Old 06-05-2014, 07:25 AM   #4
Rewards Points: 378
Touch a leaf with a Q-tip saturated with glyphosate mixed with water of a ratio approximately 1.6 oz. glyphosate / Qt. of water.
Old 06-05-2014, 07:27 AM   #5
What about weed b gone concentrate sprayed lightly on the weeds. I just planted some new knockouts nearby.
Old 06-05-2014, 07:32 AM   #6
Rewards Points: 378
Fine if you don't mind gambling on whether the spray drifts to undesirable locations and you know for certain weed be gone will kill the weed.
That's why I do things that I know will work. Wicking with glyphosate I know works, no spray to drift and uses about 1/100 of the amount of spraying.
Old 06-05-2014, 07:35 AM   #7
Fine if you don't mind gambling on whether the spray drifts to undesirable locations and you know for certain weed be gone will kill the weed. That's why I do things that I know will work. Wicking with glyphosate I know works, no spray to drift and uses about 1/100 of the amount of spraying.
where can that be purchased?
Old 06-05-2014, 07:48 AM   #8
Rewards Points: 378
Most gardening centers, Ace hardware, home improvement stores etc. will have it pre-mixed or sell the concentrate to be mixed by the customer.
I don't bend too well anymore so I attached a small sponge on a piece of lumber about 2 ft. long and a backer board to compliment it.
Old 06-05-2014, 08:01 AM   #9
Most gardening centers, Ace hardware, home improvement stores etc. will have it pre-mixed or sell the concentrate to be mixed by the customer. I don't bend too well anymore so I attached a small sponge on a piece of lumber about 2 ft. long and a backer board to compliment it.
So it's just plain old glyphosate?
Old 06-05-2014, 08:25 AM   #10
Rewards Points: 378
Yes and Round-Up is the common name we associate it with.
Some folks expect immediate results and glysophate doesn't work that way.
Old 06-05-2014, 08:27 AM   #11
Rewards Points: 20
I would work as much as I could with a cultivator, pull whatever weeds are too close to get with that by hand, sprinkle some Preen, staying back 6-8" from anything that I wanted to grow, and spread a few inches of mulch.
Old 06-05-2014, 11:47 AM   #12
Indepspirit's Avatar
Putting the glyphosate directly on the weeds is a good way to go so that you don't kill your knockout roses. Once the weeds are gone you need to take measures to prevent them from coming back. Weeds, like all plants, need light, water, nutrients and air in order to grow. So leaving bare soil only encourages weeds to grow. Covering the area with mulch helps to block out the light and air that stimulates germination. Cultivating the are may bring dormant seeds to life and will just bring more air into the soil. Also when watering the plants in that area do not spray them with a hose. Use a watering can or install a drip system. You want to water your plants directly at the base of the plant. The plant will get more water this way and be healthier. If you use a hose and spray the area you are not only getting less water to your plants you are also watering the weeds and encouraging them to grow.
Plants are like people no two alike. What I do for my plants may not work for your plants.
Dirt Ain't Cheap (my landscaping blog)
Indepspirit is offline   Reply With Quote
Old 06-05-2014, 09:04 PM   #13
I had mulch in this area before, but a contractor who looked at my foundation and the small water leak we had in our basement that was fixed with epoxy told me not to put mulch around my home. This is why I just added brown soil around the foundation. Since I have done that my sump pump doesn't go on as much when it rains heavily.
Doesn't weed be gone have this glyphosate ingredient?
Old 06-05-2014, 09:47 PM   #14
Weed be gone has Triclophyl, MCPA and Dicamba. If you have foundation leaks the contractor is correct the mulch could add to the problem. You could plant some ground cover there. That way you don't have bare soil , it will slow down the weed growth and could help with the water leaks as the ground cover will soak up the the water.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Old 06-05-2014, 09:52 PM   #15
Weed be gone has Triclophyl, MCPA and Dicamba. If you have foundation leaks the contractor is correct the mulch could add to the problem. You could plant some ground cover there. That way you don't have bare soil , it will slow down the weed growth and could help with the water leaks as the ground cover will soak up the the water. Sent from my SAMSUNG-SGH-I527 using Tapatalk
I need to pitch the soil away from the foundation. This year I need to leave it as is for that reason. If I get ground covers the downside is what if I need to add more soil later on.
Best way to kill weeds and seed. normoushoward Landscaping & Lawn Care 11 07-31-2013 01:59 PM
Turning Clover, Weeds, and Thatch to a nice lawn...eventually BrandonC_1972 Landscaping & Lawn Care 9 05-04-2012 08:31 AM
Back yard redo - Weeds out of control carquote Landscaping & Lawn Care 6 03-03-2012 09:24 PM
Eliminate weeds and improve lawn grass on a budget badtheba Landscaping & Lawn Care 8 07-04-2011 01:10 PM
Weeds are taking over...help jstcruzin Landscaping & Lawn Care 29 11-05-2008 08:06 PM
