Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 06-07-2011, 12:24 PM   #1
Hard to access spigot. Advice on correcting this?
I have an outdoor spigot that was installed on my house behind my gas meter making it hard to hook up my hose. Any advice on how to correct this problem short of installing a new spigot? Thanks!
kennykenny is offline   Reply With Quote
Old 06-07-2011, 11:28 PM   #2
sdsester's Avatar
NOPE. But you are not talking a major plumbing challenge here. Why not just move it where you want it?
sdsester is online now   Reply With Quote
Old 06-28-2011, 01:18 PM   #3
Stuck in the 70's
Blondesense's Avatar
A cheap and easy work around solution might be to sacrifice an old hose. Cut it to three feet or whatever length works, add a replacement end and just leave it on the spigot where the new end is accessible.
The Following User Says Thank You to Blondesense For This Useful Post:
1910NE (10-03-2011)
Old 01-21-2012, 05:17 AM   #4
I think one of those fancy garden companies sells a faucet on a spike. You put it anywhere and just screw a hose in both ends. The only problem I see is the hose is more likely to fail then metal pipe, so if you leave the faucet on the house on it may spring a leak between there and whatever you rig up. That would be the benefit of having the faucet moved on the house.
tractorfarmer is offline   Reply With Quote
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 10:08 PM
Hard drive redline PC Repairs & Upgrades 14 03-06-2009 05:27 PM
Changing poly type during hardwood floor refinishing redpen Flooring 17 02-03-2009 07:11 PM
Need a Little advice on redoing a Hard Wood floor hagemann11088 Flooring 1 12-17-2008 06:35 AM
Roman Tub Spigot Problems - Phoenix Corp? bkw Plumbing 1 10-17-2008 04:21 PM
