Ground Cover To Fill In Gaps In Brick Planter - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 05-18-2013, 06:16 PM   #1
Ground Cover to Fill in Gaps in Brick Planter
So I repurposed some bricks that were being pushed up by a tree root into a couple of large planter boxes. So I now have a couple of low planters made of stacked brick.
However there a re some spots with gaps and I'm looking for a way to fill them. I like the idea of using some plants or ground cover to fill the gaps and even expand over the bricks.
Ideas??? Thanks
landesb is offline   Reply With Quote
Old 05-18-2013, 07:18 PM   #2
Rewards Points: 13,458
Post a picture.
Why would you dry stack them and not morter it?
Old 05-19-2013, 06:07 AM   #3
Originally Posted by joecaption View Post
Post a picture.
Joe, the reason is because it would be pretty.
In our zone you could try creeping phlox or snow in summer. You would take plugs of the plant and jam in into the desired spots. Just don't expect much for the first season.
Check your local nursery for suitable plants in your zone.
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
user1007 (05-19-2013)
Old 05-19-2013, 10:54 AM   #4
Too Short? Cut it Again!
OP, you might want to update your profile with geographic information so we know where you are.
Any of Creeper's suggestions would be nice. Mosses might be a possibility if in a moist and shady area. Scotch and Irish Moss (dark green or light green) are fun, not really mosses, and grow in full sun.
Even small annuals like you would stuff in hanging baskets with some spanghum moss to hold them and planter mix int he cracks could work but unlike phlox or other perennial groundcovers, you would have to replant every year.
What you don't want to plant is some sort of invasive vine that takes over the brick or causes paling and heaving problems because it pries the bricks further apart and lets freezing winter moisture in.
You should put in some sort of slow drip irrigation to keep plant watered as they will dry out fast in an exposed environment like you are creating. In a way, it is like you will be planting in containers so apply the same principles and techniques. You might add some water absorbant gel to the planter mix or buy the variety with it in it.
Old 05-23-2013, 05:08 PM   #5
Rewards Points: 744
heathers can be nice too. Just go look around your local nursery. You'll find lots of ideas.
Seattle2k is offline   Reply With Quote
Tags
brick , filler , ground cover , planter
Trying to put a permanent deck cover on a 12' off the ground deck! luvsrail890 Building & Construction 11 09-16-2012 09:15 AM
How to fill a gap between basement ceiling and brick wall simonw Building & Construction 5 01-12-2009 01:00 AM
gaps in brick around house Jware Building & Construction 2 06-23-2008 02:13 AM
Gaps in drywall. What to use to fill them in. yummy mummy Building & Construction 13 01-02-2008 12:19 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
