Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 01-20-2011, 04:15 PM   #1
Burning green wood
I have taken down a load of conifer type trees and need to burn it all as not practical to remove, can anyone recommend an accelerant which I could use that is not too lethal to get the fire going- I have read that creosote is good and not too volatile? Thanks
M1ke is offline   Reply With Quote
Old 01-20-2011, 04:48 PM   #2
concretemasonry's Avatar
Burning green wood
Do not burn newly cut pine inside. - Do it outside and stack it up (away from a building) to provide a good draft. Then use some kindling at the bottom and apply some gas or something less flammable. You don't need too much to get it started, but must have some patience until it starts.
Light it and then get the marshmallows and wieners ready for when you have some good coals. If you and have a spare pig, dig a hole, put in some rocks, the wood, get the fire burned down, then the pig and cover for a day.
If you have an acre of pine cleared, you may need a different schedule.
Dick
concretemasonry is online now   Reply With Quote
Old 01-20-2011, 05:17 PM   #3
Master General ReEngineer
Bondo's Avatar
Burning green wood
Ayuh,... Diesel Fuel,....
Kerosine, home heating oils, both #1, or #2....
All pretty much the same stuff, 'n generally interchangeable...
Used motor oil, or animal greasee does the job too,...
Ya just need a propane torch to get 'em goin'....
The problem you might have is,...
Ya gotta limb 'em out, so they'll lay down better...
Otherwise, the needles burn off, 'n the wood is too far apart to git Goin'....
Basement Decorative Wood Wall Cover popping up tk3000 Building & Construction 8 10-29-2010 01:17 PM
Help Need Wood identification :D x3 iloveusk8rboi Carpentry 3 10-15-2010 10:05 PM
Home made wood burning furnace JustinK HVAC 14 10-05-2009 09:26 PM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 10:14 AM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 04:29 PM
