Arborvitae - Gardening Forum - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Landscaping & Lawn Care > Gardening Forum
Old 04-18-2010, 02:45 AM   #1
Rewards Points: 119
Arborvitae
There is a hedge of Arborvitae between our neighbor and us (is theres). At one point years ago they cut their side back to bare branches and it never came back. Our side is alive but looks terrible. There is a 10 foot stretch that is very brown, close to dead. The rest of it is green with alot of brown tips. We've tried watering, fertilizing, sprayed it with various sprays. Do they require something special?
debd is offline   Reply With Quote
Old 04-18-2010, 06:37 AM   #2
DIY staff
Rewards Points: 7,174
Acid--and sun---Check Mir-acid made by Miracle Grow--
The trees will not fill out the pruned areas--Arborvitae are cheap--might be time to replace.--Mike==
Old 04-18-2010, 07:32 AM   #3
The nursery where I buy trees sells 6 ft arbs for around a $100 bucks ea.(wholesale)
people prune arbs aggresively and they die back. very unsightly. Treat them like an eggshell. They are pretty much hollow on the inside if you trim too much green(shell) then you see the yolk(yellow)
Most common mistake is to plant for current size not mature size. If you plant with the mature size in mind then there is no need to hack away at them cuz they rub your arm when you mow the lawn.
Bushman is offline   Reply With Quote
Old 04-23-2010, 01:48 PM   #4
Rewards Points: 119
Thanks for the replies. Looks like it will need to be replaced.
Arborvitae needles Ergo61 Landscaping & Lawn Care 2 04-03-2010 08:15 AM
Emerald Green Arborvitae mwpiper Landscaping & Lawn Care 6 05-25-2009 09:48 AM
