Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 11-01-2009, 09:39 AM   #1
yellow drywall mud color
I am having mygarage drwalled. The contractor just hung everything and completed the first day of taping. Mostof the mud he used is yellowish. Are there different colors based on the brand or type? I am only familiar with it being white.
beerdog is offline   Reply With Quote
Old 11-01-2009, 10:59 AM   #2
White or grayish is all I have ever used or seen.
ausblake is offline   Reply With Quote
Old 11-01-2009, 11:27 AM   #3
Super Moderator
Yellow mud is used often -Some tapers prefer it so they can better see their work against the white paper.
My taper uses tinted mud for final touch ups so he can spot them and sand prior to paint.
Big pain when you paint an unsanded spot.
oh'mike is online now   Reply With Quote
Old 11-01-2009, 01:15 PM   #4
The contractor stopped by to check on the drying. oh'Mike was right on. He uses it to see the work better. I am planning on painting with flat white latex. Why are unsanded spots a pain?
Old 11-01-2009, 03:44 PM   #5
Super Moderator
If you have an unsanded patch and paint it--ITS PETRIFIED LIKE
STONE--good luck trying to sand out a place that is painted.
Usually you have to repatch the patch,sand and repaint.
I call that a PAIN.--MIKE--
Check your taper guys work for bad spots-It's the painters job to do small touch ups to the new drywall.-M-
Old 11-01-2009, 07:45 PM   #6
Why would it be any different than non-tinted mud?Does the tint make it harder?
Old 11-02-2009, 07:41 AM   #7
gravity always wins
No, it makes it easier to see the touch ups, so they don't get missed with the sanding pad. The paint hardens the surface and makes sanding impossible.
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
Need help with wall & carpet color scheme Cruciatus Interior Decorating 6 04-05-2008 02:50 PM
Drywall Repair + Dark Color + Repaint = Help ClemsonJeeper Painting 6 12-11-2007 09:49 PM
