Wrapping A 3/4 Ledger - Paper Faced Metal Corner, No Coat 450 Or L Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 06:58 PM   #1
Rewards Points: 288
Wrapping a 1 3/8" Ledger - Paper Faced Metal Corner, No Coat 450 or L Bead
I have the following 3 in my stash
No Coat 450
Paper Faced Metal Corner Bean
Straight Flex L Bead
I'll be wrapping a ledger that is only 1 3/8" deep x 9 Feet....
The *L* on the straight Flex is 1/2" Deep
The Laminate in the No Coat is a good 1" so if I use this.....I will be cutting out quite a bit (as there is the paper edge+laminate).
Any preference on either for this application.
I've been using No Coat for pretty much any outside corner for the most part.
mobiledynamics is offline   Reply With Quote
Old 03-29-2012, 10:17 AM   #2
Rewards Points: 288
I ended up using No Coat.
Cut the paper edge off one end....left me with 1"+ on the plastic of the no coat...which fit the ledge perfectly. Skimmed and waiting for the mud to dry, as it shrinks, to give even a nicer tighter edge...
Corner Bead for Double Drywall? whipper Drywall & Plaster 11 08-12-2009 01:19 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
attaching corner bead to metal studs ar2736 Building & Construction 2 10-28-2008 11:32 AM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 09:28 AM
Flexible metal corner bead? Worth using? yummy mummy Building & Construction 3 11-15-2007 06:09 PM
