Wood Paneling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 08:54 PM   #1
Rewards Points: 160
Wood Paneling
I have wood paneling in one room that has been painted over a couple times. I hate the look of it and want it covered (the whole rest of the house is drywall). I attempted to tear one panel off and found it was glued and nailed to 1/4" drywall underneath. Here's what I've found through research; what is the easiest option?
1. Tear off all the old paneling (which will really damage the underlying drywall), then hang new 1/4" drywall right over it. This would then have to be covered in mud, etc, primed, and painted.
2. Hang new 1/4" drywall over the paneling, mud, prime, paint.
3. Clean the paneling, cover the grooves with fiberglass tape, then mud, prime, paint.
4. Clean, cover with a wall liner, prime, then paint.
Any other ideas?
matt151617 is offline   Reply With Quote
Old 09-11-2011, 10:42 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
I choose #2.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-12-2011, 06:14 AM   #3
#2 will save you the most time......for now. I have a home with a LOT of drywall over previous wall coverings, and its a real pain if you need to get into the wall for anything.
1910NE is offline   Reply With Quote
Old 09-12-2011, 08:31 AM   #4
Rewards Points: 160
The problem I see with drywalling over the paneling is none of the trim, outlets, etc will match up anymore.
Old 09-12-2011, 11:15 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 382
True but there is going to be a trade off one way or the other, it just depends which you rather do, modify the trim or the labor to remove the paneling, either way you will have to take the trim off or do some really close sheet rock cutting.
Jim
Old 09-12-2011, 03:36 PM   #6
kwikfishron's Avatar
Rewards Points: 576
I have filled paneling grooves with hot mud (no tape), sanded and painted. You could never tell the wall wasn’t drywall.
kwikfishron is online now   Reply With Quote
Old 09-12-2011, 03:41 PM   #7
m1951mm's Avatar
I choose door number 4. I have done this soooo many times and the results have always been good. No changing outlets, no possible mud cracking out of a joint and a lot less mud work to do to get to a good paintable surface.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 09-13-2011, 03:08 PM   #8
Military Mom of 4
Snav's Avatar
I'd do #1.
Yes - most time consuming. But I wouldn't stop at the old drywall - I'd just tear it all down, hang new sheets - mud tape - enjoy the freshness.
I absolutely hate leaving up old work and just 'living with it' underneath.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
old wood paneling... redsphoto Painting 13 04-21-2011 11:39 AM
Couple Questions on installing real wood 4x8 beadboard paneling (Georgia Pacific) RickDel Carpentry 4 07-07-2010 02:46 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 01:31 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
primer for wood paneling HELP! Sarah24 Painting 3 03-25-2008 01:01 PM
