-   -   window box is further out then drywall (http://www.diychatroom.com/f101/window-box-further-out-then-drywall-78225/)
spyd4r 08-08-2010 02:56 PM
2 Attachment(s)
Hello all, the previous owner half finished the basement and didn't work too professionally I may add.
As you can see below, parts of the window box protrude further then the drywall in numerous places.. by about 1/4"
so I can't put window trim up easily... as it either won't sit flush to the wall or the window box.
whats the easiest way to correct this?
Thanks in advance.
oh'mike 08-08-2010 04:14 PM
Obviously you will need to remove that---Might be easiest to rip it out and remake the jamb extenders.
If you have an undercutting saw like the Bosch Fine Cut you could saw it flush--At $100 or so might not be practical.
An elevated stepped router base would do the job--with a straight cutting bit.
If you have a router ,,I'll try to talk you through making a stepped base out of some scrap plywood.--Mike--
spyd4r 08-08-2010 04:24 PM
thing is it's not evenly 1/4" out.. on part of the window its flush and parts its not...
really not sure what to do.
Tom Struble 08-08-2010 05:33 PM
nail the moulding to the extension jamb,shim the back of the trim where needed before you nail it to the wall...little caulk,little paint...you know the rest:wink:
oh'mike 08-08-2010 06:03 PM
What tools do you have?
spyd4r 08-08-2010 06:41 PM
i have the usual must haves + chop saw, skill saw.
no advanced work working stuff though or knowledge of how to use it either...
boman47k 08-09-2010 07:35 AM
Why not cut almost to the wall perpendicular to the window with a jigsaw as close to the corners as possible. Then pop a line between the cuts. Ajust the saw blade for slant of the seal. Cut the line. Finish with a planer flush with the wall?
Do the uprights first. Get the uprights out of the way then just pop a line from side to side for the horizonals flush with the wall. Toe kick saw might be needed for the corners of the horizonals, unless you can use a sawsall to get to them by getting as close as you can with the jig then tilting the sawsall to get the corner pieces. May have to spread a little mud to cover some damage from the sawsall.
Might be best to still leave the horizonal a little proud then flushing with a planer.
Got a belt sander? May be able to use it instead of a planer.
spyd4r 08-09-2010 10:14 AM
think i may go with this method... seems like it involves the least work...
i'll test it on one window first and go from there.
boman47k 08-09-2010 02:06 PM
If I understand this correctly, your facing will be box like with tapering/differing depths?
gmhammes 08-10-2010 03:15 PM
multimaster or even a flush cut saw would do it. Is the wall itself straight though?
boman47k 08-10-2010 03:32 PM
If your blades are like mine, it may take several.
gmhammes 08-10-2010 03:49 PM
Yeah, the wood cut blades for my multimaster i haven't been really impressed with however i ordered some non fein blades so we'll see how they work.
