Will Primer Make A Difference - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-13-2014, 02:28 PM   #1
Rewards Points: 83
Will primer make a difference
I'm getting ready to paint my bedroom walls. I cleaned them and removed the baseboard but I have lots of small drywall repairs to make. The walls have an orange peel texture on them so I went out and bought hormax orange peel sprayer. I'm going to prime the entire wall before I paint it anyway but my question is do I have to prime the patched spot before I put the texture on or can I just put the texture on then prime the whole wall.
ttwin is offline   Reply With Quote
Old 04-13-2014, 07:26 PM   #2
Rewards Points: 626
Prime texture then prime agian. Just spot prime the patches. you said you were going to prime the whole thing? so spot prime texture then prime the whole thing two coats of paint and done.
Nailbags is offline   Reply With Quote
Old 04-13-2014, 07:59 PM   #3
Rewards Points: 480
Just put the texture on and prime the whole wall. Anything else is just extra work. Ron
ront02769 is offline   Reply With Quote
Old 04-13-2014, 09:32 PM   #4
Rewards Points: 83
thanks
Old 04-14-2014, 08:18 AM   #5
Rewards Points: 5,978
I always prime before and after texture repairs. But hey that's just me.
Old 04-14-2014, 11:58 AM   #6
Rewards Points: 83
Do you think it ruin the paint job or cause flashing if I don't prime before I texture?
Old 04-14-2014, 01:55 PM   #7
No I really don't think it will hurt anything. I just do the extra to be sure most will probably say it's overkill.
Old 04-14-2014, 02:00 PM   #8
Rewards Points: 83
[QUOTE="ToolSeeker"]No I really don't think it will hurt anything. I just do the extra to be sure most will probably say it's overkill.[/QUOTE
Thanks for the overkill advice then :-)
The Following User Says Thank You to ttwin For This Useful Post:
ToolSeeker (04-14-2014)
Old 04-15-2014, 04:52 PM   #9
Rewards Points: 83
Turns out the directions say to prime first, add texture then prime again.....so here goes nothing.
The Following 2 Users Say Thank You to ttwin For This Useful Post:
oh'mike (04-15-2014), ToolSeeker (04-15-2014)
Old 04-15-2014, 07:38 PM   #10
Rewards Points: 744
I have a pretty light orange peel. After replacing drywall in my kitchen, I found that if I primed first, the Homax texture "sat up" more, than if I did not prime. Therefore, for my application, I only primed after. It ended up blending very well.
Seattle2k is offline   Reply With Quote
Old 04-15-2014, 08:29 PM   #11
Sounds like your light orange peel may have been stipple from the roller. Can be hard to tell the difference.
Old 04-18-2014, 08:42 AM   #12
Rewards Points: 674
I just used this product to patch a few spots on my orange peel ceiling. Practice on a piece of old drywall or whatever. I got the professional that had more controls.
My only piece of advice that worked for me is that when the spray on texture is mostly dry, take a nappy roller and roll the area you sprayed. That will push down the big bumps while the shallower orange peel is already dry.
You may have to do a few times.
B
Beepster is offline   Reply With Quote
Will adding a return make a noticeable difference? thundercats HVAC 7 12-18-2012 10:37 AM
White thinset and Gray Thinset, does it really make a difference.. yummy mummy Tiling, ceramics, marble 25 02-03-2012 11:00 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Bathroom paint/primer Termite Painting 11 07-02-2008 02:28 AM
