Will Drywall Fit Through This Door? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 04:08 PM   #16
Rewards Points: 5,974
Originally Posted by MT Stringer View Post
Is it a pro no no to simply cut the sheet in half...one extra seam?
Not just another seam, a long hard to deal with butt joint.
I have 2 ideas,
1. how hard would it be to remove the window PITA yes.
2. 1/4" drywall will bend quite a bit. Maybe try 3/8" but won't bend as much. If code is for 1/2" you may have to double up the 1/4"
Old 01-05-2014, 04:52 PM   #17
Rewards Points: 4,780
The room above is 16 x 16 with 9 foot ceilings.
It's not the end of the world to cut boards in half, but it probably increases the taping labor by at least 50%, I would think. All butt joints too, which is bad.
4 options are cracking the panels, cutting the panels in half, bringing them up through the ceiling, and taking the window out and putting it back in, assuming a track can go back there.
jeffnc is offline   Reply With Quote
Old 01-13-2014, 04:40 AM   #18
Rewards Points: 324
Did the crack the boards trick when drywalling my parents beach house's wc rooms that were too small to get a full sheet in and stood up. Taped and mudded all the seams as usual, where the board was cracked put a single coat of finish compound to hide the line that was barely noticeable, sanded and painted. That was in 1997. It has held to this day.
mgp roofing is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
drywall around exterior door Harlan Craig Drywall & Plaster 1 08-06-2011 02:28 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Wrapping closet door opening with drywall mfc133 Drywall & Plaster 7 02-20-2011 04:48 PM
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
