Will Drywall Fit Through This Door? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-02-2014, 08:38 PM   #1
Rewards Points: 4,796
Will drywall fit through this door?
Trying to drywall an attic space. The door and initial "foyer" are shown below. Looking at it, I don't see how drywall will fit through, but sometimes people know tricks I don't. There is a window in the attic space, but the window would have to be completely removed and reinstalled, and we might not even be able to get a truck back there anyway.
http://sdrv.ms/1hknESm
Did I mention the attic has 9' ceilings? So the drywall would need to be 4 1/2' wide, or 9' long.
The door is at the end of a hallway. As you face the door, there is a bedroom door immediately to the left. Otherwise, the left wall of the hallway would preclude bringing in a sheet angled in from the left. The first photo is taken facing the door from the hallway, the second photo is taken from the bedroom door just to the left of it, and the third photo is taken after stepping through the door and turning 90 degrees to the right, while standing in the "foyer". The ceiling of the foyer extends 40" to the right before it opens to the attic ceiling.
jeffnc is offline   Reply With Quote
Old 01-02-2014, 09:07 PM   #2
Rewards Points: 5,974
From the pics it looks like you might be able to stand them up inside the door. Even if it works real PITA.
Old 01-02-2014, 09:15 PM   #3
Won't be able to stand them up in the foyer - immediate 8" steps, foyer only 90" high. They would have to be angled to the right.
I will have a chance to try it when hanging a small area first, but if it doesn't fit I just would like to know if there's some trick of angling the pros know.
Old 01-02-2014, 09:56 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 564
Go buy a sheet and take it for a test drive
The Following 3 Users Say Thank You to TheEplumber For This Useful Post:
kwikfishron (01-05-2014), oh'mike (01-02-2014), Sir MixAlot (01-03-2014)
Old 01-04-2014, 07:28 PM   #5
Rewards Points: 512
for some reason i cant see the picture. i've had a couple of 100+ year old homes where i couldnt get even a 8' sheet up the stairs. i'd either take a window out and have them boomed up there. or what i'd do is cut the back side of the sheet and fold it up without cutting or wrecking the good side bring it up stairs and carefully open the sheet and install it on the wall.
princelake is offline   Reply With Quote
Old 01-04-2014, 07:31 PM   #6
That's clever, but does that work structurally speaking? Sounds very risky.
Old 01-04-2014, 09:00 PM   #7
Rewards Points: 6,652
If you really have to, you can always cut them on the back, fold them over, but do not tear the face paper. That will give you a 4x4 section to take up there. Easier to do if you did not have that wall in the way, or had a window large enough upstairs, that they can be boomed in that way.
Old 01-04-2014, 09:34 PM   #8
Rewards Points: 18
Could you cut a hole in the ceiling of a room below and pass the new drywall up into the attic through it. Then you would have a fairly simple repair to make in the ceiling.
ST180 is offline   Reply With Quote
Old 01-05-2014, 07:50 AM   #9
Rewards Points: 512
being 9' ceilings cut the boards at 3' and have 3 horizontal on the walls
Old 01-05-2014, 08:07 AM   #10
An old Tradesmen
Rewards Points: 6,918
Old 01-05-2014, 08:46 AM   #11
Rewards Points: 153
If there's an open space between joists large enough, I'd cut a hole up through the ceiling. If you're working alone, make a stand for the sheets right below the hole, so you can slide a few sheets up and have them sit there on the stand. Then go into the atttic and pull them up as you need them. Depending on the roof slope and joist spacing / depth, this could still be a tight operation. You may be stuck with folding them and bringing them up the stairs, in which case you may want to take the handrails off - only one way to tell.
eandjsdad is offline   Reply With Quote
Old 01-05-2014, 12:06 PM   #12
Handyman
brucem609's Avatar
Rewards Points: 79
Crack the boards just like prince said. But be careful you do not rip the paper on the front side. Slow and steady. 1 at a time. Get 10' boards and you will do fine
Sent from my iPhone
brucem609 is offline   Reply With Quote
Old 01-05-2014, 12:17 PM   #13
I'm shocked at the advice to crack the boards. But then I did come for suggestions I hadn't thought of.
I mean, I'm just having a hard time believing the drywall will still be structurally sound. Does it have to be cut precisely where it will be attached to a stud? If not, will cracked drywall really hold up fine? I just have a hard time being sure of that. It seems like you'd see a line there or something, in the final result.
Passing the drywall up through the first floor ceiling and then repairing it is another interesting option. Thanks for the ideas.
Old 01-05-2014, 01:02 PM   #14
I would think as long as you were careful to keep the locations of the scoring/folding to occur over studs or perpendicular to them, they would act just like typical joints between panels. When the slit is over a stud, fasten both halfs of the panel. When perpendicular to studs, each half of the panels spans from stud-to-stud. If you score in the very middle, you'll have two 4' sections which should put the score over studs @ 16".
The drywall doesn't need THAT much structural integrity - just enough to resist regular impact without breaking. Placing a seam parallel to studs, but between them would leave cantilevered edges that would be vulnerable to impact.
I like the idea of sliding the panels up between floor joists. Also, in a tight enough space, you might be better off cutting them into more manageable pieces anyway (long strips or squares) even if it means more joints to finish.
Edit: Remember if you plan to crack/fold the boards, you'll need ample room to unfold them (4' wide space), but I think you are talking about a larger room above these narrow stairs?
greenfrog5 is offline   Reply With Quote
Old 01-05-2014, 01:26 PM   #15
MT Stringer's Avatar
Rewards Points: 248
Is it a pro no no to simply cut the sheet in half...one extra seam?
MT Stringer is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
drywall around exterior door Harlan Craig Drywall & Plaster 1 08-06-2011 01:28 PM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
Wrapping closet door opening with drywall mfc133 Drywall & Plaster 7 02-20-2011 03:48 PM
Security screen door dangerp Carpentry 4 09-22-2010 07:02 PM
